Dave Drums
I got 2 pairs of IEM's. My old CCA C12 and now they are my new C12 thanks to Slater's micropore mod, and right out the box T2 plus
Very Nice! Do tell what this 'Micropore mod' is?
This should make you smile
KZ EDR1 vs UiiSii HM7?
I finally finished my KBEar KS2 Review. You can read it here: https://www.head-fi.org/showcase/kb-ear-ks2.24470/review/24295/
In the end, I don't get the point of the KS2. I still don't understand why KBEar decided to release KS2 whereas the (better overall) KB04 exists. Perhaps some might like it for the soundstage, not for me however. The shouty mids and peaky lower-treble and boomy bass just doesn't cut it for me. Looking forward to their next release with more balanced tuning. Till then... ah well.
You really can't go wrong with the blon 03. The real question is if it fits well. I find them to fit well but many have noted that the nozzle is on the short side and some have placed spacers before the tips, effectively extending the nozzle.Need recommendations for my first iem, I'm looking to spend under $50. I enjoy a warm sound signature. Would the Blon bl 03 be the best option along with an upgraded cable or are there better options in that price bracket ?
Ah, good call on the heat shrink / ear hooks. I used a eyelash scissor to remove them, allows the blon 03 to sit in place much easier for my ears.BLON BL-03 is a good option. But u might need to top up a bit on aftermarket tips (longer tips) as the stock fit is bad for a lot of people due to the too short nozzle. Personally I like spinfit CP 100 and 145 on it, but some also do a reverse KZ starline or use other aftermarket tips or spacer mods. Aftermarket cable is a plus/minus, the stock cable earhooks are stiff and tend to yank the IEM out of the ear. BLON BL-03 is good for timbre and tonality, but not the best for technicalities, so if u are looking for a very technical IEM for critical listening or something with very complex music/fast movements, you might need to consider a hybrid/multi BA type IEM.
If u can still find the TFZ Tequila1 on Aliexpress, they are clearing sales now, it was about $53 USD when I last bought it at the last sale, slightly above your budget. It was north of $100 before, very warm and bassy (basshead set). Technicalities are average, non fatiguing, good soundstage and timbre, good fit and accessories.
Over these 2, I would recommend the Final Audio E3000 if u can find one, usually about $40 - 50 USD, warm and mildly V shaped, good timbre and tonality, non fatiguing, excellent soundstage and imaging. Mids are quite well done. Only thing is it has a crappy non detachable noodle thin microphonic cable. I manage to eliminate most of the microphonics by using a shirt clip or wearing it over ear, but the longevity of a non detachable able is another issue. Midbass is a bit slow and nebulous. Isolation is bad, so also not the best option to be used on the go, and it is very power hungry, needs an amp to scale to its best performance.
