CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
seanwee
- Jun 9, 2015
You can reshape them by heating them with a hairdryer.... and here are my Apple USB-C -> 3.5mm with some stress relief :
Is there anyway to straighten those cables (NICEHCK 8 Core High Purity Copper Upgrade Cable) where they attach to the IEMs? They are really stiff.
Barusu Lamperouge
Actually I bought ED9 as a replacement to Fiio F3.While I started with 1 More and Fiio, it is exactly KZ that got me hooked into ChiFi with AS10 - loved the journey ever since
I posted my CCA Ca16 review last night, for someone looking for a very articulate near neutral its hard to imagine getting more for $60.
https://www.head-fi.org/showcase/cca-ca16.24390/reviews
PhonoPhi
CCA C16 with a nice silver cable for a perfectly articulated treble, as the mantras go
(and for me for the B&W aesthetics and the nice looks & fit)
NiceHCK has to be commended for shipping the cable under two weeks! Some companies deliver despite all circumstances!
P. S. Typo editing
RikudouGoku
Member of the Trade: RikuBuds
What cable is that?
(and for me for the B&W aesthetics )
NiceHCK has to commended for shipping the cable under two weeks! Some companies deliver despite all circumstances!
PhonoPhi
NiceHCK Litz 4N pure silver, under $20 and what I love compared to TRN - no smell, cleaner plastics are used by NiceHCK.What cable is that?
RikudouGoku
Yeah I was also very interested in that cable, but slater measured it at 1 ohm and thats quite a lot...NiceHCK Litz 4N pure silver, under $20 and what I love compared to TRN - no smell, cleaner plastics are used by NiceHCK.
PhonoPhi
You've intrigued me.Yeah I was also very interested in that cable, but slater measured it at 1 ohm and thats quite a lot...
The wires are fairly thick.
OK. I've measured.
I do not have a very precise multimeter, but relative to the multimeter circuitry, of 0 3-0.4 Ohm, it measures 0.8-0.9 Ohm, so more than 0.5 Ohm, but about this value -and the same as most (and quite a few) 16-core cables I have (TRN silver (T3) indeed measures lower - 0.3 Ohm or so).
RikudouGoku
Do you just use a multimeter or do you have something else when you measure cables? Slater scared me away from getting a multimeter since soldered some stuff to use with it.You've intrigued me.
OK. I've measured.
PhonoPhi
I use decent ($50) multimeter, but definitely not for low resistance measurements.Do you just use a multimeter or do you have something else when you measure cables? Slater scared me away from getting a multimeter since soldered some stuff to use with it.
At work, I have very precise devices, but the main problems are the wires and the contacts.
I do get measurements of 0.9-1.2 Ohm for common KZ cables; 0.6-0.8 Ohm for KZ upgraded ones, 0.4-0.6 for most 16-core cables I have; and I have one 8-core cable and TRN T3 that measures 0.3 Ohm or so.
For my purposes these measurements are fully sufficient, but not "to publish".
So I would be curious and happy to hear what Master @Slater can tell us about - this silver NiceHCK and the measurements.
IEMusic
Hmmm, is that what’s primarily responsible for a lot of the sound changes I notice with the TRN T3? A lot of times, I don’t notice much difference in sound with different cables, but with the T3, I do. Maybe it doesn’t have much to do with the fact that it’s silver? I wonder how the Tripowin C8 compares to the Zonie 16?I use decent ($50) multimeter, but definitely not for low resistance measurements.
RikudouGoku
maybe its your other cables that have more impedance and they are the ones that change your sound? Then when you go to the T3 you hear the "true" sound?Hmmm, is that what’s primarily responsible for a lot of the sound changes I notice with the TRN T3? A lot of times, I don’t notice much difference in sound with different cables, but with the T3, I do. Maybe it doesn’t have much to do with the fact that it’s silver? I wonder how the Tripowin C8 compares to the Zonie 16?
Slater
https://www.head-fi.org/threads/low...ck-cable-thread.891911/page-301#post-15753197
RikudouGoku
Such a shame that the TRN T3 cables arent available with 4,4mm I would have gotten a few of them otherwise.
Total: 44 (members: 0, guests: 44)
