ShakeThoseCans
First of all, thank you all for your suggestions. Good first experience with Head-fi it's really nice to get so many and varied responses.
It doesn't seem a good idea for me to get the LZ A6 mini right now. I'll first apply the advice of using larger tips, a different cable and possibly a hair dryer to see if I can get a good fit with my KZ AS06.
I'll also read up on the mentioned eartips, the V90s and other suggestions. Where can I find info on good 2-pin replacement cables?
I'm glad we can be helpful. Many of us have been purchasing excessive numbers of Chi-Fi IEMs recently, so know the score about what is what.
I looked at my notes on the V90 to find out what the recommended cables and tips are. Here is what they say:
TRN V90 Accessories
EARTIPS
-Tennmak Turbo Whirlwind Ear tips (or similar) might do them more justice than foam tips
-Spinfit CP145, since the V90s insert pretty deeply.
-JVC Spiral Dots
-TFZ wide bore tips in Large size. "The V90 body is too small and it's impossible to get a seal with regular tips. I usually love TRN tips but they don't work with the V90. TRN really should include a set of large wide bores."
"I've had mine for a week now. I'm amazed at how good they sound. I did run into the issue of not being able to get a seal with normal silicone tips due to the small housings but luckily I have the 14mm wide bores that are included with TFZ iems. There's also a pair in the P1 box and the Tin HiFi T2 box. Lifesavers right there for me. I also found 3 pairs in my old tip graveyard bag from some MEE sets circa 2008."
JVC Spiral Dots are next but there are also a few inexpensive options on Aliexpress.The secret if you're having the fit issue is using a 14mm tip size.
CABLE
-Senlee 8 core single crystal cable for best results.
-TRN T1 so-called "Tiger" cable:
https://www.aliexpress.com/item/4000110478221.html
[This one is visually appealing, but it has been noted that the number of cores soldered in may be less than 8].
-TRN T2 Silver-Plated Cable
-Kinboofi 8 Core [which goes down to about $25 during sales]:
https://www.aliexpress.com/item/32956046016.html
-I am using the NiceHCK 8 Core SPC, which is comfortable:
https://www.aliexpress.com/item/32914622984.html
-NiceHCK 8-core copper cable
Most of these cables go on slight or extreme discount during major sales. "Tiger" goes from $8 to less than $7.50, Kinboofi 8-Core should go from $47 to $25, NiceHCK 8-Core SPC goes from $11 to $9.50.
Someone is also pushing the 4-core Litz cable, which is on special today, although I find that most people buy silver-plated cables for the V90.
https://www.aliexpress.com/item/4000515816813.html
