Slater
But I have sold off my ZSN Pro to my colleague tho
Just keep it in mind for any future earphone you have a similar problem with. It works for any earphone with BA drivers in the nozzle.
Will do, thanks for the tips manJust keep it in mind for any future earphone you have a similar problem with. It works for any earphone with BA drivers in the nozzle.
Agree 2 pin is sturdier and more hardy than an MMCX, though I have seen my colleague snap off a 2 pin cable inside the IEM housing before. But I suppose if you don't keep disconnecting and connecting cables frequently from your MMCX IEMs, and just leave the cable be, their lifespan shouldn't be an issue.
dealing with mmcx connectors for me is easy, chose one cable to your liking (new), put it there and dont change it if possible
I can agree about fun hot tuning. Other aspects of the zsn pro is pretty decent except the hot treble
Limited painful replacement is synonymous with MMCX indeed!dealing with mmcx connectors for me is easy, chose one cable to your liking (new), put it there and dont change it if possible
Slightly off topic but MMCX is the main reason I won't buy a pair of Solaris.
One can smash any type of connectors, even military-grade.
I never had any functional problems with two-pins in more than twenty IEMs.
Insertion/detachment of MMCX is always a pain - feels like two states: too tight or two loose...
For the low voltages and currents of IEMs, there is no point at all, in my opinion, in using MMCX, which has it origin, I believe, in shielded cables.
I used this adapter on my mmcx cable but one of them had caused the socket very loose, aka it had widened the cable's socket. Also, they are very hard to remove because they are very tiny.I dunno if this will help, but I've seen some people buy a MMCX to 2 pin adapter, something like this:
There are smaller ones than these, and they're all available on AE and most online shops. Whether it will degrade the audio signal and make the fitting weird/unasthetically pleasing is another story though. Never tried one, so maybe anyone can advise?
I guess these are similar devices to "socket savers" that are used in amps and other stuff to prevent wear and tear of the socket. It might be worth a punt IMO for expensive TOTL IEMs. I'm not a fan of MMCX connectors too, but it's pity that you guys give a miss to some good sounding IEMs just because it has an MMCX connector.
free rotating is good sometimes since you can adjust how the cable hook on your ear, but if they keep rotating, it does become annoying as heckWeirdly enough I thought I was missing something out with the MMCX cables, the main reason being that I heard some people being amazed that it was featured at a certain price point. I myself tried to stay away from it, the free rotation which I heard was a problem to some, was not something which I would tolerate at all. In all views the two pin is more attractive, especially the good ones where they are recessed in a housing, and thus preventing possible damage.
It's good to hear that actually a majority is attracted to the two pin, and prefer it over a MMCX cable.
True, thinking about it, when I was using earphones, the main issue was that each time that I'd take my phone out of my pocket and put it back, the cable would twist.. with MMCX this wouldn't be the case as you could just rotate it and untwist it. Never though about it like this, but people complain about it making a noise when rotating.free rotating is good sometimes since you can adjust how the cable hook on your ear, but if they keep rotating, it does become annoying as heck
