My EP10 pair is defective....so, even if i kinda like stock sound, I get annoy by the defect in one side. anyway, there were too much sub bass, to important drop in upper mids-lower highs and this tend to make treble spike sound unatural and invasive in some track. But it add air as well in soundstage, wich was the big PLUS for me. Vocal was quite nice too...now, compared to BL-03 its way more unbalanced and U shape but a little upepr treble spike would have been nice with it too (without the crazy drop of EP10)
BL-01 sure look crazy bargain, we need a graph ASAP to give them more credibility!!
BL-01 appeared after the BL-03 on AliExpress. It was only available on one store when I pulled the trigger on it.
The sensitivity is totally different to that quoted for the EP10 and what my ears hear is very different to the graphs posted there and the descriptions I have read of the EP10.
The BL-01 is tuned quite close to the Tin T2, in that it isn't a basshead IEM by any means. Timbre is on a par with the BL-03. Soundstage is very "intimate" but instruments are located very precisely. I know there was a guy who said that the EP10 sounded like a £20 IEM and the BL01 sounds like £100. He is overstating the case for the 01 but it's definitely worth mentioning in the same breath as the usual £30 suspects. Probably not as good as any but close enough given the price difference. They're also really sensitive so play nicely as a "plug in and go" with a phone as a source. I rate them as better than the **** (Too shrieky) and the MH755 (Too woolly) but everyone's ears and tastes are different. Definitely the bassheads should ignore it but if you find the Tin T2 bass adequate when amped up, the BL01 will be fine.
Damn! Look VERY interesting. I mean, in this price range, any gems is more than welcome. Soundstage scare me, but easy driveability and mostly 03 kinda a timbre and less bass (03 have a little too much sub bass for me and isnt that well controled) hook me. Did it have at least some mid bass punch. Would you say they are more neutral or mid centric or ?
Fairly neutral I would say. There is probably a bit of a spike somewhere in the low treble as they sound pretty detailed in the highs. Bass is more fast and punchy than plentiful. Until they burn in bass guitar and bass drum blend together a bit more than I would like but it does clean up a bit.
I notice you own the Tin T2. If you like that then the BL01 will suit you. In the same way the Sony MH755 sounds a lot like a Blon BL03 but somehow "cheaper" the Blon BL-01 sounds like a lower budget Tin T2. I've actually got them in my ears right now. They're not the best headphone I own. They are the ones I listen to the most.
That sucks. No sign of them on Ali. Maybe TaoBao if you know how to buy on there.
I'd offer to sell you mine, but... No. These are MY Blon BL-01.
Edit - Yeah, they are on TaoBao but I can't read Chinese. I've PM you the link as I'm not sure about the rules.
Edit 2 - shallow fit eartips complaint with the 03 applies to the 01 too. Spiral Dots sound AMAZING on them.
Oh wow. Seeing them disappear has made me think I need a spare pair. I listen to music I like. I listen to music I don't like so much. That to me is a sign of liking the reproduction equipment. Not to mention that I plugged them in when I got home at 7pm. It's nearly 10pm and I haven't moved.
Looking for something to listen on the go. The last IEM I got was the KZ ZS6. I was looking at Tin T2 and Blon BL03. Everyone was raving about the T2s and now they sound boring and lack baas. The Blon 03 is hot currently but they need a new cable. That's basically what I gathered so far. I don't know what to get. Anything better in that price range?
What source are you using? What sound are you after? Fwiw the Tin T2 is neither boring nor lacking in bass if properly driven and fitted with good tips (ideally foams). As for the cable on the 03, I have no issue with the stock (though I have changed cable for something a bit heavier now.)
Yea I have no issues with using the Blon cable now that I cut the plastic ear hooks off. Im not going to say its a great cable, but its fine. On par with stock KZ and TRN cables.
