CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
May 17, 2019 at 12:34 AM Post #17,943 of 31,834
OK, got a reply from Chen. He said the new BT20 will support aptX HD. No aptX Lossless though.
i hope it also adds volume control, and maybe some easier way to charge (like charging case, for instance)
May 17, 2019 at 1:48 AM Post #17,946 of 31,834
I am more or less an Android person but I do own an iPad. TRN didn't say it is AAC compatible so I assumed it is not. However, I do know it is using Bluetooth 5.0.
Anyway, the new BT20 will be both AAC and SBC compatible.
I can confirm AAC compatibility of the current BT20 on Android. My Redmi Note 5 shows the codec used with the currently active connection.
view
May 17, 2019 at 4:45 AM Post #17,952 of 31,834
Then again, there are B-stock Knowles drivers which many Chi-Fi manufacturers use and advertise themselves as using Knowles.
yes i was thinking that they use B stock or second hand knowles drivers, also the banned brand use knowles for bass and mids and bellsing for treble in my HQ10 to keep the cost down
however the treble response is very good, smooth and natural sounding
