DBaldock9
Hi there,
I'm looking for sub 25$ IEMs.
I've gotten really confused trying to choose the best IEMs at this price, there is just too much of a choice:blink:
What would you recommend to someone who listens mainly to Rock/alt Rock music and likes balanced sound with a nice bass oomph?
Thanks!![]()
Tennmak Pro is a good choice in my opinion, but there are other alternatives that does well for that genre as well.
I just ordered and received the "2016 New Kinera BA05" and the "2016 DIY DD3 Double Unit Moving Iron Hybrid Dynamic Balance Armature" earphones (both less than $25) - and they appear to be the exact same item, except for having different labels, "KINERA" & "OKCSC" on their sides.
I'm quite impressed with the sound quality, especially considering their low price.
With them connected with a balanced cable to my DP-X1 (Digital Filter: Sharp), and no other EQ, or with an unbalanced cable to my iFi Micro iDSD (also no EQ) - The Bass response goes really low, without being boomy; the Mids (vocals / acoustic guitars) are balanced & smooth; and the Highs are clear and detailed, but not quite as prominent as some of my "V shaped" earphones (like the Senfers).
https://www.aliexpress.com/item/2016-New-Kinera-BA05-In-Ear-Earphone-Monitor-Dynamic-with-1-BA-Hybrid-HIFI-DIY-Earphone/32750398448.html
https://www.aliexpress.com/item/2016-DIY-DD3-Double-Unit-Moving-Iron-Hybrid-Dynamic-Balance-Armature-HIFI-Monitor-Sport-Wire-with/32712301469.html
I also have the Tennmak Pro, which is in the same price range, and sounds really good as well. They seem to have a little more mid-bass / mid-range, bringing the sound "forward" a bit. On a personal note - the size & shape of the Tennmak Pro allows me to get a better fit & air seal.
https://www.aliexpress.com/item/Tennmak-Pro-Dual-Dynamic-Driver-Professional-In-Ear-Sport-Detach-Earphone-with-4-drivers-inside-Vs/32624020655.html
If you don't need the maximum isolation of an in-ear earphone, you might also consider the **** PT15. I use these with an over-the-ear cable, for a more comfortable & secure fit. They don't have quite the same bass impact as the in-ear models, but they still have a good amount of bass - and a bigger, more open sound-stage. They're also more comfortable for extended listening sessions.
https://www.aliexpress.com/item/New-****-PT15-Earburd-Graphite-bush-Dynamic-Driver-In-Ear-Earphone-HIFI-Earplhone-With-MMCX-Interface/32756183154.html
Any of these will provide good quality sound, for ~$25.
Take Care,
David Baldock
