- Sep 14, 2009
Thank you, Michael (Mercer). Looking forward to seeing you in Newport soon!
Anyone here have trouble getting the Dacmini via usb to work through wasapi?
I'm using J.River Media Center and I can only get music to play using "direct sound". If I try wasapi or wasapi-event style, it says I need to change the settings to 24/96 but even when I do it doesn't work.
Before this I've been feeding it optical/coax without any issue.
Hi Poetic,
If you're comparing the DACport LX to the DAC section of the DACmini CX, they are very similar with any given amplifier, but especially so when the USB port that's supplying power to the LX is "noise-free" and can supply the 500mA of current at 5 votls that's supposed to be available according to the USB 2.0 spec.
The DACmini's DAC section is far more consistent from one PC to the next, because it has very stable and clean power thanks to how it remanufacturs the power coming in from any DC supply of 9V to 19V with at least 2.5 Amps of current.
In terms of sound signature, assuming the LX is not compromised by power quality, I personally can't hear much difference when I'm routing the output from the LX into the DACmini's amp section vs. using the DACmini by itself - except that my LX doesn't quite have as much air and micro detail as my DACmini's DAC - and that very subtle difference is only detectable with tracks that have a lot of blackness around a brush on cymbal, for example. My noise floor is pitch black with both the LX and the DACmini (as long as I'm not using the LX on one of my laptops that has noisy power when its plugged into its AC charger). But again, as long as power quality is ideal for the LX, it sounds pretty much the same as the DACmini's DAC - which is terrific!
I'm just kidding, of course, but don't forget the DACmini CX has a great amp, too!
Are you going to jump on one of the B-stock DACmini CX units (for $550)?
Mike
Im planning on using the Hifiman He-500 headphones along with the HE-400 on the CX so i would need driving power. Would the B - stock be the version to get ? Also i was looking at the New Hifi M8 and i was wondering if i should just wait for that
