ssportclay
- Aug 27, 2003
I am not familiar with the Pickering hybrid but I do have 2 CineMag CMQEE-3440A transformers on order to be used as step-ups with my Hagerman Bugle.These transformers were designed by the same person who designed the
Altec 4722 and reports indicate that these 2 transformers sound very similar.I am going to wire these so I have access to the 1:36 tap only which will result with a load of 37.5 ohms.This would be useful for most low output moving coil cartridges.Load resistors should not be required.A 1:18 tap is available on this transformer should the Pickering hybrid require a different load.A pair of these will cost $104.22 delivered from CineMag, Inc. I don't think you can do much better than these transformers at any price.Lots of information is available at the Vinyl Asylum.You can thank Garth for bringing this transformer to every one's attention.He just passed away not long ago.
Originally Posted by Black Stuart /img/forum/go_quote.gif Hi memepool, since you brought up the MC v MM thing. I use a Pickering V15, which is so musical, I have given serious thought to buying the top of the range Pickering hybrid, which needs a step-up Tx - any thoughts appreciated. |
