Yes and No.When using in BT receiver mode (ldac or uat), does EQ work?
When you connect N8 in BT receiver mode, it become a slave to your mobile phone (or whatever BT transmitter), the N8 behave like a wireless (BT) DAC/Amp, the control of your music playback is not rested with your mobile phone (i.e., the Master in the BT connection), so you cannot access the EQ UI in N8 once you connected.
However, it you have set your EQ prior to your BT connection, it will remain in the playback chain AFTER the N8 enters Slave mode, hence you are listening to your N8 wireless DAC with EQ, so it does work, but you can't change the EQ setting unless you disconnected the BT connection.
Stay updated on Cayin at their sponsor profile on Head-Fi.
