Doug2507
@Andykong im looking to change out my 400gb SanDisk extreme for a 1tb card. Are any of the Samsung / lexar cards considered compatible?
Actually I am curious that you mentioned SP2000 does not have enough power compared to your other DAPs. However, I see you are even using an external amp (eg Romi amp) with your devices for headphones. Wouldn't those DAPs need not have to connect to an external amp if their build in one is so good?Sound was not deep nor enough power. EQ horrible , battery below average.
SO2000 had issues with TH900 , with Final Audio D8000 Pro planar loves power.Actually I am curious that you mentioned SP2000 does not have enough power compared to your other DAPs. However, I see you are even using an external amp (eg Romi amp) with your devices for headphones. Wouldn't those DAPs need not have to connect to an external amp if their build in one is so good?
Sure, I understand the Sp2000 part lacking to run headphones.SO2000 had issues with TH900 , with Final Audio D8000 Pro planar loves power.
Not about need nor about loud plus I added an amp to the SP2000. All these daps sounded good without the external amp , but theres something more with an amp.Sure, I understand the Sp2000 part lacking to run headphones.
What I don't is that why need an external amp for your DAPs to run your headphone? This puts the other DAPs equally weak since you must have added the external amp as you must find something lacking in them.
I can second this. I listen with another DAP that would drive my Focal Stellia with ease BUT it sounds even a tic „better“ with an external portable amp. You don’t „need“ it, particularly for such an easy to drive headphone like mine, but with additional power it shines even more.Not about need nor about loud plus I added an amp to the SP2000. All these daps sounded good without the external amp , but theres something more with an amp.
I never upgraded FW all is going great. I just transfer music and its in the dap no scanning needed.I've successfully downgraded by Cayin N8 BB to firmware 2.5. I'm finally having a glorious experience again, no longer do I need to use Hiby Link exclusively to control my music. 2.5 is snappy and provides excellent sound quality. The solid state balanced output especially stands apart from the rest.
