Rozeqloud
- Apr 12, 2012
Well i was sent a new N8 from dealer
It`s on FW 2.0, maybe its all in my head, but my HD800s did not sound this epic on 2.3
i know FW is not supposed to influence the sound, so i 've heard
My questions are
1. i`m using balanced for my HD800s, and in the menu i discovered -LO-Balanced mode(Maybe that's why the cans sound so epic,i never used that b4).So much power
My concern is,i noticed in that mode there is no control over volume what so ever,it seems preset by that option(Man will you be surprised if you have the system set to continue from a song u left off on..BOOM!!)
Is this normal,is my N8 ok? Is there a way i can control volume from this setting?
Changing anything like gain as well has no effect while in this mode
2. Advice on a quick charger was given before, from Andy, but just on brands,i will take his advice and get an aukey
i do not want to damage my N8 or the battery so i ask you, can i get a quick charger with too much wattage?
i have found QC chargers from 18 watts to 60 watts, but i think the 60 watts may be divided between the 4 ports, where the 18 watt is a single port
i figure more watts = a faster charge? Am i correct?
Can i overdo the wattage on a QC and damage my N8 or battery?
Is the wattage the N8 limited to Ie 18 Watts, but does it have a safety that will only allow the Ie 18 watts, no matter how many watts my QC will be capable of?
Cheers
LO is a fixed line out
*** i am daft
Please forget that daft comment
i like it tho,is it ok to use it? i dont get that power from any other setting..odd
