Does N7 allow for offline storage of Tidal songs thru the Tidal native app?
Because whenever I try to do download stuff, it just keeps hanging on downloading without ever doing anything.
I have re-installed completely the app multiple times, cleared the cache downloads, cleared the entire downloads also, but nothing seems to make this work.
After clearing the cache and doing a full system wipe and using recovery mode still no WiFi or Bluetooth on the N7 @Andykong any more suggestions?
I was considering the new N6III but thinking might not after this wifi and Bluetooth shouldn't just stop working for no apparent reason.
Similar to laptops, WiFi and Bluetooth share the same wireless transmission module. If both are not working and resetting doesn’t fix, it’s likely that the flex PCB wiring has come loose due to a drop or impact. You may need to send it back to our factory for repair.
If you would like to proceed, let me know! I’ll have the aftersales department get in touch with you.
I was in the same situation: it was just lying on the table and the amplifier part just failed. You may have to send it for repair, it should be free under warranty, I hope you can restore it - they couldn't fix mine and returned it. Unfortunately, the player turned out to be very unreliable
Hi people got a question. Cayin N7 and uapp player app. If I set uapp to bit perfect “on” does the dsd512 upscaling still work on the N7?
I know uapp does some android bypassing, just wondering if that affects the upscaling of the N7.
It still sounds amazing so I’m assuming it’s still all working upscaling wise.
Thanks people.
I’m using uapp for a while before going back to hiby player and cayin player apps. I’m wanting to give it a proper try before going back to those others players.
Got to say the user interface is so smooth even with 2tb installed on uapp!
I’ve had that issues and had to select the proper download path for whatever reason. Might be a bug but it works now so I don’t know what I did really.
Hello everyone. Recently I bought Cayin N7 for my collection. In my opinion this player is closer to the flagship level. A very decent option for relatively little money.
