Mr.HiAudio
Member of the Trade: RIOBuds
Maybe your application was updated before shutting down and the system was unable to boot after it? What applications did you have installed?So had to reinstall all apps etc
Not many app installed; Hiby Music, Qobuz, GAIA - for Go Pods. That’s all.Maybe your application was updated before shutting down and the system was unable to boot after it? What applications did you have installed?
After LPG, you will definitely miss the high ones in N7. If you take the stage, then the N7 has more volume and widerhello, are there those who compared lotoo paw gold and N7? I want to understand what is the difference between them in terms of sound pitch?
I wrote above that I had problems with different cables that did not provide a reliable connection, so I found a cable that does not lose connection, here:charging/transfer cable people could recommend?
