asdfasdf
- May 12, 2004
How does the E01 compare/share similarities with AK SE100? Both have similar ESS DAC, I'm curious whether they sound similar to each
Good question, I don't have the SE100 but I do own the E01. The DAC chip used is only one part of the equation though. I'm prepared to bet the discrete class A/AB output stage in the E01 makes a difference to the sound vs the AK DAP, but how much?How does the E01 compare/share similarities with AK SE100? Both have similar ESS DAC, I'm curious whether they sound similar to each
Since the last update I understand that the HiBy music app now supports MQA. Does this mean that it can now connect to and stream music from TIDAL?
I think the previous person who replied to you misunderstood your question. Cayin N6ii was certified to support mqa unfolding in hw when using Tidal app or playing standalone MQA flac files. HibyMusic app was not updated to function as UAPP. Unless there is some secret hidden feature
Stay updated on Cayin at their sponsor profile on Head-Fi.
It could be another bug from the FW update. @Andykong any ETA on the next FW update to address these issues? For me the N6ii is totally unusable now. Luckily I have an R8 coming in a couple of weeks, which leads me to think that I would probably sell my N6ii. I don’t see a point of keeping something that’s unusable.
That’s fine. N6ii for me is unusable at the moment. I’m not looking for sound improvement with R8, what I’m after is better battery life (my E02 only lasts 6.5-7 hrs), better UI speed, and more power output.
My video review is up:
Sound strange to me, you said N6ii is not useable because we can allow user to set digital filter, that is a sound related problem, I fully understand this is annoying for someone who put audio on top priority, but when you said you are not looking for sound improvement with R8, I am confused.
I have an issue when playing some songs since I got the E02 board. Sometimes the first second of a song is skipped and the song actually starts with that first bit missing. It therefore ruins the intro and is pretty annoying. It doesn’t happen on every song and I cannot see a pattern to it, but it happens enough that I would like to solve it. Does anyone else have this problem and can it be corrected?
Same here. E02 out of the box - and the same problem no matter which player you use - uapp or hiby.
I think we might want to hear the official feedback regarding this problem. Yes, @Andykong?
One problem that has emerged is that, when playing a Tidal Masters track, 88.1 or 96 kHz will appear at the top Initially and there’s a lag before it registers the next two unfoldings. When it switches to eg 384 kHz, there is an interruption to the track. It’s only half a second, but very annoying. Anyone else experienced this? It didn’t happen immediately after the update was done. But now it’s every time.
I only listen to Tidal, both online and offline. I will do some checking and report back.Just to confirm, the skipping problem only happen on E02, it won't happen with E01. Theoretically both Audio Motherboards are ESS based, so there is a large chance that they'll encounter.
As someone has mentioned, does it happen when you change between PCM and DSD? changed to a different sampling frequency rate? Change to a different format (e.g. FLAC to AIFF?)
We have run into similar problem with N5ii, and the problem was solved subsequently. Not sure if this is the same problem, I need to gather more information before I submit the bug to Engineer.
I would just go by the sampling frequency. The base sample rate is almost always going to be either 44.1kHz or 48kHz. The first unfold will double this sample rate. The second and third unfolds usually happen together. Each unfold doubles the sample rate. Here's a table I created to show this:
The first unfold is usually done in software. The second and third are usually done in hardware. Each unfold essentially doubles the sample rate. So you get:
Base sample rate = x 1
First unfold = Base sample rate x 2
Second unfold = First unfold x 2
Third unfold = Second unfold x 2
Remember that the second and third unfolds are usually done together - i.e. you don't normally end up with the sample rate at the second unfold unless your DAC cannot handle the sample rate that the third unfold would produce.
What we had before this latest firmware update was just the first unfold in software (i.e. the TIDAL app or the UAPP app with the MQA add-on acting as an MQA Core Decoder). What we now get with the update is the N6ii acting as an MQA Renderer - so it takes the first unfold from an app (TIDAL, HiBy) and performs the second and third unfolds (depending on the module/DAC capability). The T01 is limited in its top sampling rate so that's why it's limited to the second unfold.
That's my understanding at the moment! Happy to be corrected.
I will try that today and report backIs this Audio Motherboard related? Does it happen with downloaded MQA tracks? or happen with all Audio Motherboard? Can you download a few MQA track from 2L and verify whether the problem is related to everything under MQA or just Tidal Master.
The MQA implementation varied quite a lot among different Audio Motherboards. so it is important to clarify the situation first.
I’ve tried a few tracks from 2L and then played the same track in Tidal Master. Not only do I not get the same problem, but the quality is many times better on the same track as an MQA track from 2L than it is on TidalI will try that today and report back
We are working on a new beta firmware during this weekend, if we can solve the problem with this firmware, we should be able to release a new firmware by early next week, but before I receive green light from engineer, I don't have a firm ETA.
Anyway, just to confirm that we have been working non-stop to solve the digital filter problem. MQA implementation related to digital filters, we must make sure our bug fix does not affect MQA before we release a new firmware.
Hello @Andykong I’ve done some testing. I listen to Tidal and have tried both online streaming and offline download. Songs are in three groups: 44.1k, 352.8k and 384k. (Before the firmware update for MQA it would have been 44.1k, 88.2k and 96k for the same tracks) I took a playlist and moved songs around so that there was a good spread of having different kHz next to each other. My playlist was 40 songs and the skipping happened on 4 songs. On each occasion the skipped bit of the intro happened on a 44.1k song, but this was when it immediately followed after a 352.8k or 384k song. It didn’t happen on any other combination. I then moved those 4 affected songs around so that they were all immediately after another 44.1k song. This time the 4 affected songs played fine with no skipping at all.Just to confirm, the skipping problem only happen on E02, it won't happen with E01. Theoretically both Audio Motherboards are ESS based, so there is a large chance that they'll encounter.
I have found a good track to test this on. It is a folk song called ‘Here’s the Tender Coming’ by The Unthanks. I normally use this song to test female vocals. What is good about this track is that the singing starts immediately and so you can tell exactly where the skipped part is. The lyrics start, ‘Here’s the Tender Coming...’ but when this track follows a 352.8k or 384k song it goes, ‘....he Tender Coming...’
I hope that is of some help.
I would also mention that this also happened on the E02 before the firmware update.
