normie610
So when you connect the N6ii up to a Mac via a USB cable, does it show up as a drive on the Mac? I’ve had issues connecting Android devices to my iMac and Android File Transfer breaks Bluetooth on my Mac. If it does just appear as another drive then all will be well.
What I do is I don’t connect the N6ii, I insert the SD card into iMac’s memory card slot and just do a straight copy from Finder. If you do have Apple Music and have the “Sync Library” turned on, you can also download Apple Music app from Google Playstore and have your music there. But since Apple Music app is using N6ii’s internal storage (including downloaded songs for offline listening), it will be limited to the available space in your N6ii’s storage.
