mashuto
- Sep 23, 2016
I’m sure the screen protector should be installed. There is also a spare one in the package. This is a new unit, I’m sure about that, however the case... It’s so ugly. Ordered the Dignis case immediately. The dealer has already sent me the adaptor but still, my unboxing expectations were a bit higher...
Did you buy it with the e01 module? There's no 4.4 input on that one so I could see it potentially not being included.
As for the screen protector... It's been brought up a number of times in this thread. Due to the "2.5d" curved edge screen I believe cayin switched to using a gel screen protector that molds over the edges. It's trash. Seriously, it sucks. Any kind of pressure and it crumples and comes off the edges. It kinked up as soon as I put the case on. I consider it protection for shipping and that's it. Use the glass protector that was included. It's fine, though due to the screen it doesn't sit flush at the edges.
I think you will likely be more pleased with the actual usage of it even if your unboxing experience wasn't great.
