@Andykong
I see my issue has been discussed before , can I ask
1- do you mean all daps with 4.4 will have the same issue with interference
2- can that be corrected with an upgraded motherboard ,
3- if not can you tell me which 4.4 cable can we buy to solve this issue as to be honest its annoying for people who rely on streaming, as I mentioned I sometimes hear interference or noise in between tracks especially when I turn on wifi and stream tidal
finally also the volume wheel sometimes does not work perfectly, like u need to rotate it few times before it moves to the next level.
Anyhow as with every product I expect imperfections in hardware or software, but for me the interference thing needs to be solved unless this happens on every 4.4 mm device, and if does not happen on every 4.4 device, and you suggest a cable change, then please direct us to a company from where we can buy cables that will solve this issue
as for sound yes its a great sounding dap period so i give that to Cayin
