PinkyPowers
Reviewer: The Headphone List
Sorry I haven't been very active the last few days. Been sick since Christmas Eve. Hopefully I'll be up to more Cayin N5II stuff soon.
I was able to install the new firmware very easily using the manual internal storage method, and the interface is much faster, thanks! I can also report when using my iphone as a source (with the new lightning adapter that splits power and data) and the Cayin as a DAC/headamp in DAC mode, I'm getting static with the music. I tested it with headphones through the 3.5mm HO. Is this normal until a future firmware update, or is it something to do with my setup?
Did you try the dac mode even without the split adapter?
The source of the static could come from the adapter.
Get better soon!Sorry I haven't been very active the last few days. Been sick since Christmas Eve. Hopefully I'll be up to more Cayin N5II stuff soon.
you are correct, i tried it with the iphone (with adapter) plugged into a different outlet and no more static, so it may have been coming from the powerstrip or some other interference. thanks!
By the way - if anyone has questions about this player, i can do my best to answer or test some feature.
Not exactly related but possibly related. I was charging an ipad on a plane while playing a movie, and got static in my FLC8S. Unplugged the charger, and no more static.
So yes, static can be passed through adapters and chargers in some instances is my conclusion.
I don't recall we have App Store pre-installed in CN version firmware, I'll check that out for you.
The QQ Music are quite popular and a lot of N5ii users in China has installed this app and it is working fairly stable. The situation is, if N5ii cannot work with QQ Music in China, it'll be like claiming N5ii support streaming but Spotify will crash frequently - we'll run into serious trouble in no time.
However I am not sure if the app is fully functional outside China. Plesae be remind that some streaming app are operated within certain geographic area only because their music license are not global based.
Has someone else experienced problems with the 2.5mm jack? @Andykong, were you able to check this with your team? AMP3 has a good deal, and they expect restocking in 5th Jan.
Stay updated on Cayin at their sponsor profile on Head-Fi.
Question guys.. been using my N5ii and absolutely loving it. I noticed that there are different skins for the player. I noticed that sometimes these skins show up as daylight themes (light/bright) and other times they are blue (night/dark theme?). I haven't been able to figure out how to toggle between the day/night modes on the skins. Anyone been able to figure this out?
