originalsnuffy
Where are people getting the Amazon HD app? From the Amazon underground store, or other sources?
Google Play store. It’s the Amazon Music app... good luck getting it too work.Where are people getting the Amazon HD app? From the Amazon underground store, or other sources?
Hey, great idea... never thought of that one..I’ll try as well when I can find time. Thanks for tip to try...Well, Amazon seems to indicate that the app should be sourced from their store which is, I think, called the Amazon underground. My suggestion is to try downloading the app from there and see if that improves matters. I have tended to sideload apps but in this case I think I may actually stick to the suggested source. When I get around to it....
Wow. It works like a charm in the DP-X1. I don't understand. I tried downloading the apk version of the Amazon Music app also, with the same results.
Andy - is Cayin looking into the Amazon HD issue?
Thanks
Stay updated on Cayin at their sponsor profile on Head-Fi.
Yes, there were a volume control bug in the early version firmware. The volume bug was a random issue, not everyone is having it, it just happened on some player under certain condition, we have corrected the problem already. Maybe the demo unit had not been updated its firmware for a long time, I guess update the firmware to latest version should solve the problem.
Same problem here with N5IIS. Had it replaced by local dealer.Hi Andy,
I have been listening to the Cayin N5II for several months but for a few days I have a problem, the screen does not turn on anymore.
I still have the little white light above the screen, that's all.
I tried to stay 10 seondes to make a reset but that did not give anything either ...
I do not know what to do, could I have some help, I thank you
This unit is the poor little lost engine that almost made it up the hill. I think I can I think I can..
