seanwee
- Jun 9, 2015
Good to know thanksSame with me, I've done two cycles, zero freezes, also no new apps installed, no Wifi, audio priority mode only BUT I connected it to my Mac to download music files on both SD cards plus the internal memory, no issues there either.
I still won't be connecting it to pc yet just in case since originalsnuffy(I think) said that he thinks that the file management of the N5ii is not too stable.
Edit: Yeah I was right
With regard to adding files and then having problems, here is something that sometimes helps. On my unit it is really easy to corrupt the "file system" on individual memory cards. With Windows 10, I periodically run chkdsk. There is also a program called DiskFresh that I have used for similar reasons.
Transferring files to and from this unit is a buggy process right now. I am not entirely sure that Cayin intends to address it.
Last time I brought up the USB issues Cayin simply pointed me to a section in this long thread about USB issues. The long discussion left me with the impression that the USB subsystem was not particularly well implemented in the hardware design.
I still think some software tweaks can subdue most of the problems.
I have been left with the impression that Cayin is not even trying to fix the USB transfer issues which is a problem in its own right. Maybe Cayin can pipe in and set the record straight.
