Ugeek
- Apr 3, 2016
So this is a new instance. Lets explore the condition in more detail.
The issue is when you changed the setting of Custom EQ, then go to EQ Off, played two songs, and then switch back to Custom EQ, the EQ setting that you just adjusted are gone and the Custom EQ fall back to previous setting? or the Custom EQ always fall back to zero dB at all frequency setting?
I have just test the Custom EQ setting and my steps are as follow:
- Play a song from TF
- Set Custom EQ to a very abnormal pattern to make sure this is the test setting
- Press Return key to Quit from Custom EQ setting mode
- Continue to play song,
- Check later, new Custom EQ is correct
- Power off and power on again, play music
- Check Custom EQ setting again, still in place, all frequency setting is as setup in (2)
I need to repeat your error before I can file the case for trouble shooting and push for a solution or a firmware adjustment, so lets see if we can repeat the error here.
Hi Andy.
The error occurs without any pattern, always on a 48Hz song, but also on others. It plays well and suddenly the sound changes but not the EQ (visually I mean). The 2 kHz band is concerned only.
Plus every time I switch the player off, it doesn't keep the custom EQ as preset and always goes back to eq off. I must say that it's not a big deal but annoying
Thanks for your help.
