- Nov 16, 2013
Hi everyone, I'm new to this forum and a happy owner of a N5!
I just have one question for this nice Andy : I'm a little confused with the equalizer that I set to custom and returns to "eq off" between 2 songs! And other detail, the presets I put in the customed eq change on their own... Weird.
Specially the 2kHz, that I set to zero. It remains on zero but the sound is like they're on the middle of the scale.
Otherwise, it's a great great player.
Have a nice day.
thanks!It occurs when I play local files through the headphone output exactly... I have the latest firmware, 3, I checked.
So this is a new instance. Lets explore the condition in more detail.
The issue is when you changed the setting of Custom EQ, then go to EQ Off, played two songs, and then switch back to Custom EQ, the EQ setting that you just adjusted are gone and the Custom EQ fall back to previous setting? or the Custom EQ always fall back to zero dB at all frequency setting?
I have just test the Custom EQ setting and my steps are as follow:
- Play a song from TF
- Set Custom EQ to a very abnormal pattern to make sure this is the test setting
- Press Return key to Quit from Custom EQ setting mode
- Continue to play song,
- Check later, new Custom EQ is correct
- Power off and power on again, play music
- Check Custom EQ setting again, still in place, all frequency setting is as setup in (2)
I need to repeat your error before I can file the case for trouble shooting and push for a solution or a firmware adjustment, so lets see if we can repeat the error here.
Stay updated on Cayin at their sponsor profile on Head-Fi.
