looks too big
Cayin N3Ultra: an Entry-level Portable DAP that Delivers a Complete Vacuum Tube Audio Experience
- Thread starter Andykong
RONJA MESCO
For better viewing, click the Youtube title to enjoy the media in fullscreen
In 2024, Cayin enters its 10th year in the portable product line.
August 17, 2020, marks the launch date of the N3Pro DAP. As the first portable audio player equipped with the NOS vacuum tube JAN6418 (Joint Army-Navy designated military grade components) produced by Raytheon, it was the first in the sub-$500 price range to achieve dual vacuum tube timbres (triode and ultra-linear) and solid-state timbres in a DAP. Coupled with its relative portability, long battery life, low heat generation, and suitable pricing, it became one of Cayin's best-selling audio players.
Now, three and a half years later, the N3Pro's upgraded replacement model, the N3Ultra, is about to hit the market. We have debuted the pre-production samples at Canjam New York 2024 and released some preliminary information and photos on the HeadFI forum.
We shall present the N3Ultra today covering its features, functions, and design aspects of the DAP.
Photo Below: N3Pro on the left, N3Ultra on the right:
A major advancement in the batter against microphonic
The N3Ultra continues to use a pair of NOS vintage tube JAN6418 from Raytheon for the vacuum tube timbre. Although Cayin has not used this tube in other products over the years, the optimization of the circuit and structure for better utilization of this tube in portable products has never ceased. The JAN6418 is also one of the very few vacuum tubes that can be used in battery-powered portable products, given the various limitations of portable products on heat generation, power consumption, and power supply. However, its disadvantages are also very clear, namely its susceptibility to microphonic effects and poor resistance to interference from wireless signals.
On the N3Ultra, the JAN6418 is encased in a custom-molded silicon housing and installed on the left side of the DAP. It integrates into the chassis with a suspension structure, achieving comprehensive stress relief for the tube's filament. Meanwhile, Cayin's engineers have further upgraded the circuit architecture originally used for the N3Pro. By introducing an appropriate amount of inter-stage loop NFB to further inhibit the closed-loop gain, and employing FET to control the power supply of the vacuum tube, we can deliver a significant improvement in the stability of the operating current of the tube filament.
With the refinement and upgrade in structural installation and circuit architecture, the N3Ultra has effectively overcome the microphonic effect of the JAN6418. When users select one of the two vacuum tube timbre in the N3Ultra, whether walking with it in hand, carrying it in a backpack, or even during jogging which might involve vigorous shaking, the microphonic effect will not impact the music experience.
These features are open for audiophiles to verify in practical listening and usage. However, due to the physical structure of the JAN6418, unconventional scenarios like tapping the left side of the device with a finger or physically knocking it against a table surface can still produce a relative microphonic effect.
Gen3 Vacuum Tube Circuit: Taking JAN6418 Implementation into Another Step
Like the N3Pro, the N3Ultra offers two types of tube timbres: Classic (like the N3Pro’s triode circuit connection) and Modern (like the N3Pro’s ultra-linear circuit connection), providing an easier-to-understand nomenclature that highlights the tonal differences between the two circuits. The Classic timbre is thick, and warm, with rich overtones, best suited for vocal performances but weaker in dynamics and transients. The Modern timbre has a more open soundstage, with stronger extension at both ends and linearity. Thus, the naming follows the same definition as the N30LE, indicating consistency in sound presentation.
In its overall circuit architecture, the N3Ultra achieves a comprehensive application of tube timbre, allowing for the adjustment of the two tube timbres on both 3.5mm/4.4mm headphone output and 3.5mm/4.4mm line level output, marking a significant functional upgrade from the N3Pro.
Additionally, whereas the tube output power on the N3Pro was nearly half that of the solid-state output, the N3Ultra maintains equal output power for both tube and transistor timbres. This is the result of years of Cayin engineers’ research into the application of this tube circuit. We have changed the application of the JAN6418 in the N3Ultra circuit by using it as a low gain voltage amplification device (previously used as a BUFFER in the N3Pro without gain amplification), and incorporating a hardware analog volume controller to suppress the inherent noise of the tube.
However, it is important to note that the JAN6418 is a single-channel tube, with one tube handling only one audio channel. In the N3Ultra, when using the tube timbre for balanced output, the signal from the timbre circuit is inverted and serves as an inverted phase before feeding into subsequent amplification stages. Strictly speaking, the 4.4mm balanced headphone and line output are balanced driven, but this is not a fully balanced circuit from DAC to LPF to amplification. Conversely, the transistor timbre maintains a fully balanced process throughout.
A Complete Portable Vacuum Tube DAP Experience
Some users might wonder, "why only two vacuum tubes are used in the N3Ultra and not four?"
The JAN6418 tubes, produced mainly in the late 1970s and early 1980s, have relatively poor consistency compared to modern products. Using vacuum tubes in audio products requires testing and pairing before they can be used in the same device. The process of pairing two or four tubes results in a very low yield rate. Moreover, considering the need for the N3Ultra to be compact, lightweight, portable, and easy to operate, and to incorporate anti-vibration structures for mitigating the microphonic effect, it is physically impossible to accommodate four tubes within the N3Ultra. Therefore, the only practical solution is to use signal inversion for balanced transmission and amplification. We rather tell you the truth and assure you that we have done all we can to deliver a solution that is properly engineered, and practical for its designated purpose.
Additionally, due to the production processes of the time, the JAN6418, or traditional vacuum tube products (as opposed to the KORG Nutube 6P1), have very weak resistance to interference from wireless signals. When the tubes are close to antennas or wireless devices, users may hear a noise like a "sizzling" sound through the headphones, which severely affects the audio experience, turning the carefully designed tube sound into a potential flaw. These issues were experienced in our previous models, the N8 and N3Pro, which featured OTA wireless updating and bidirectional Bluetooth/Wi-Fi music transfer, necessitating internal antennas. Many users reported noise when listening to music when they selected vacuum tube timbre, and the problem was typically resolved by instructing them to turn off the wireless function after receiving a photo of the device's screen during playback.
Therefore, we have decided to get rid of the antenna with N3Ultra, this implies Bluetooth, or WIFI or features like online streaming will not be supported. Cayin is determined to let N3Ultra users to fully experience the exquisite and captivating sound of the vintage JAN6418 tube. All the decisions and compromises are made with this goal in mind. We are fully aware that the limited functionality may deter some users from choosing the N3Ultra and limit the circulation of this DAP. The focus has been primarily on the application and design related to the vacuum tube audio, which is a significant aspect of the N3Ultra, . This is our deliberate choice and commitment to develop a dedicated HiFi product for our users.
The Hardware configuration and performance
The N3Ultra's DAC employs two AM4493S chips in MONO mode for fully differential output, with a hardware analog volume controller NJW1195A from JRC. The DAP delivers a maximum output power of 600mW (at 4.4mm balanced phone output with 32Ω impedance), THD+N of 0.008%, and an SNR of 120dB.
Regarding the control system, the N3Ultra utilizes Android as its underlying operating system, with extensive optimizations to maintain the advantages of Android in touch display and charging management. The main processor is the Qualcomm 425, and the N3Ultra features a 4.1-inch HD 720x1280 TFT-LCD screen, breaking the limitations of the X1000E platform (whose maximum resolution does not exceed 800x480), and offering smooth touch operation.
The N3Ultra also features a new, closed pure audio system design for its UI, offering a clean and straightforward user interface. This closed system dedicates the hardware solely to music playback. It lacks internal storage but supports external TF cards and bidirectional USB DAC functionality, as well as coaxial SPDIF output embedded in the USB-C connector.
In terms of battery life, the N3Ultra is equipped with a 4500mAh battery supporting QC3.0 fast charging. Its battery life spans up to 12 hours or more in 3.5PO transistor mode and 8 hours or more in 4.4PO tube Classic mode. Weighing just 200g and with dimensions of 125x65.5x19.5 mm, the N3Ultra is compact and easily handled with one hand, making it more suitable for on-the-go use compared to the likes of the N30LE and N8ii. Additionally, it boasts excellent temperature control due to its simplified circuitry, which keeps the device relatively warm even in confined spaces.
Price and Availability
The N3Ultra will retail at US$529 and it will be available by mid-April 2024. We shall demonstrate the N3Ultra at two major events before we ship the DAP to our dealers: the Shanghai Headphone Expo by the coming weekend and the CanJam Singapore on April 6-7 2024. We shall try our best to showcase the new DAP to our users and press members before they make any decision,
Both the N3Pro, released three and a half years ago, and the upcoming N3Ultra, are unique in offering dual tube timbres plus a transistor timbre, totaling three timbres, under the $800 price range. While there may be limitations, these products are the result of ongoing refinement, innovation, and progress, stemming from Cayin's three decades of accumulated expertise and breakthroughs in vacuum tube technologies. Everyone can incorporate vacuum tubes into their amplifier, but utilizing them effectively and delivering an immersive audio experience is another. Cayin will live up to your expectations on the journey of high-fidelity vacuum tube applications.
two things...I am glad you guys showed the the pro and the ultra units side by side--letting us know how much more were getting with the Ultra. And the price, though increased, is not bad for a unit with tubes in it. If this was some other brands, it would've been $800 or more out the gate.
Wow, thank you! Now I'm really looking forward to receiving my MusicTeck pre-ordered N3Ultra. This DAP hits the sweet spot in price and performance for me. Allows me to set aside my current DAP and portable hybrid tube amp stacks and just enjoy being on the go and carrying a single device with switchable full tube or SS timbre.
Z_Showmaster
Member of the Trade: Zeppelin & Co.
"When the tubes are close to antennas or wireless devices, users may hear a noise like a "sizzling" sound through the headphones, which severely affects the audio experience, turning the carefully designed tube sound into a potential flaw. These issues were experienced in our previous models, the N8 and N3Pro, which featured OTA wireless updating and bidirectional Bluetooth/Wi-Fi music transfer, necessitating internal antennas. Many users reported noise when listening to music when they selected vacuum tube timbre, and the problem was typically resolved by instructing them to turn off the wireless function after receiving a photo of the device's screen during playback."
Using the M3 Ultra when it is lying on the laptop or right next to it with WiFi and BT turned on as in the photo below - does it not affect the sound quality?
We're talking about RF components right beside the tubes, in the chassis of the player. The tubes are shielded from external sources by the chassis.
Of course, you could always use a longer cable if that makes you feel more comfortable. But Wi-Fi 7 modems and 5G signals have infinite reach everywhere anyway, so...
I'd take confidence from Cayin's track record with vacuum tubes and Nutubes. I've never encountered interference on them before, so rest assured RF noise won't be a bugbear here.
LostnAmerica
Would that be two stupid or tu stupid? LolMy only criticism would be to loose the graphic above the volume wheel, it cheapens the classy look and if you can't figure out that forward increases the volume then you are to stupid to own one!
Just a bit of fun
LostnAmerica
Ay chihuahua!... Yo creo que tampoco!
Looks good!
Is there an improvement in sound compared to the pro?
I have all my expectations on this model, but the battery life?
- Oct 6, 2013
Wanted to mention, for anybody interested, I talked about N3 Ultra in my CanJam NYC report, toward the end when you scroll down here. Also, no issues connecting to my Galaxy S22 with a short usb-c otg cable to use it for streaming, pretty much like a jumbo usb-dac dongle with a built-in battery. Furthermore, didn't notice any interference picked up by tubes since they are isolated from the streaming source
ToneDeafMonk
Previously known as TheDeafMonk
I Would believe you over a second hand report.
Z_Showmaster
I guess I ought to come out and admit that our demo's chassis is rigged and made of lead, to give the impression that there's no interference
(Obviously, I'm kidding, right?)
- Oct 6, 2013
I don't know under what condition they tested it, I can only speak for myself and my test results. After the show, I was able to borrow N3U from Musicteck for a quick test at home. N3U is literally on top of my phone with BT on (getting incoming notifications to my watch) and wifi on (streaming Amazon Music HD), and there is zero interference. Oh, and I find it to have an excellent pair-up synergy with Amber Pearl
audionewbi
- Jan 24, 2010
How is the heat, will I be able to put it in my pocket? As much as I love my N8ii, it just too bloody hot.I don't know under what condition they tested it, I can only speak for myself and my test results. After the show, I was able to borrow N3U from Musicteck for a quick test at home. N3U is literally on top of my phone with BT on (getting incoming notifications to my watch) and wifi on (streaming Amazon Music HD), and there is zero interference. Oh, and I find it to have an excellent pair-up synergy with Amber Pearl
hanumanbob
Seems a bit odd to do this but I know woo offers a very nice but expensive one.
- Oct 6, 2013
Well, N3U is a stand-alone DAP to begin with. But since people were asking how to use it for streaming, I tested it with my smartphone. Also, I don't believe Woo Audio was at CanJam NYC, would have loved to test it otherwise. But from the spec, their Tube-mini dongle is almost as long as N3U dap and looks like a big USB stick without a battery. Plus, 1W @ 8ohms max output can translate into a heavy battery drain while connected to your smartphone, and it costs $500. Tube-mini sounds like a good solution for demanding headphones and is probably better to use with your laptop as a source.
