I am not sure if I understand Audiophile PT's question correctly. I assume you are referring to the wonky know that Willdo7474 mentioned. In that case, we didn't change our design or manufacturing process. They are the same as the first day we introduce the DAP.
The volume knob of N3Pro is a multifunction control, it covers power On/Off, screen wake up/dark out, and volume control at the same time. To enable all these, the control knob need to rotate and push in (or described as click by some reviewer) on different occasions, that means we need to left a 3mm to 4mm gap behind the knob so that it can be push in, and that is where the wonky feeling come from when you rotate the knob.
In addition, this design will introduce small "gap" when you start turning the volume knob, making it not responsive enough if the user want to micro-control the volume slowly (and precisely) for 1 dB ony. In our design, if you want to control the volume per dB precisely, we suggest you use the + and - control in the volume control screen. N6ii will bring up the Volume Control screen immediately when you turn the Volume control konb.
We have recieve around a dozen of repair cases that involve the volume knob in the history of N3Pro, the two major casues are tear and wear and physical damage caused by drop/impact or presurrized by heavy object in backpack. So far the repair rate of volume knob is acceptable when compare to our other DAP product. For the record, N6ii shard similar volume knob design, while the volume knob of N6ii might look smaller, the chassis and the volume guide are stronger. It offers more protection in drop/impact test and the related repair rate are slightly lower when compare to N3Pro.
