LostnAmerica
Regarding your issue with the firmware: Greetings SemiAudiophile, I just got mine also and I was having the same issue with the downloading of the latest version (v2.3). I noticed you have a Surface computer. I have a MacBook and I used my iPhone to download the file, then I dropped it to my Mac and then copy and pasted to the N3 which was directly connected to the Mac. Realizing you have a different computer (OS), I hope this helps hen it took, all automatic. here is a brief communique with Andy:So I took the link you sent and I was successful with my iPhone, I saved it and dropped to my Mac and hooked up the N3, and transferred it. It was a workaround to get it but it worked. I think I was having issues with the CN website on not being allowed to download or something... there you go. Thank you Andrew for all the helpful info! BTW, the sound is incredible with my HP-2'...So just got the N3Pro today but I'm running into some issues.
1. It won't recognize as a USB dac on either my phone or surface laptop. Using the same OTG cable that came with RU6. Tried other cables as well.
2. I having the hardest time getting the firmware to install. Currently it's on v2.1. Downloaded v2.3 on to my microSD card that is formatted in NTFS. Inserted card and it detects that microSD is inserted. But when trying to perform update, says no memory card detected. Same error with OTA.
@Andykong any ideas?
Other than that, it does sound great through Bluetooth on LDAC. UAT works but I get constant connection drops.
Cheers
