Cayin N3 Hi-Res DAP with AKM4490 DAC, apt-X Bluetooth, and Line, USB & Coax Out for $150
Need help
Trying to connect N3 with chord mojo with usbc coax cable
When playing a song on N3, Getting very high levels of output from headphones connected to mojo. Such a high sound output can surely destroy headphones as well as eardrums. Is something need to be done within the N3 settings?
No volume control on N3 from usb.Need help
Need help
When you connect N3 to Mojo in coaxial, N3 acts as the source and output the original bitstream. you have bypassed the DAC and headphone amp circuit inside N3 and therefore no volume control. You should control the volume on the Mojo instead, which function as DAC/Amp.
When you said very high sound output, so what are you comparing to? Before you listen to N3 as your source, what was the source of your mojo? your mobile phone connect to USB input of Mojo?
Stay updated on Cayin at their sponsor profile on Head-Fi.
Andy
any idea when the N3 Pro will be available in the US?
First i connected N3 as source. output level from mojo was too high.When you connect N3 to Mojo in coaxial, N3 acts as the source and output the original bitstream. you have bypassed the DAC and headphone amp circuit inside N3 and therefore no volume control. You should control the volume on the Mojo instead, which function as DAC/Amp.
Then connected to my android phone using USB C to USB A cable. Everything was ok.
I read somehere that mojo needs DoP signal via USB C Coax cable. I think N3 S/PDIF setting needs to be on DoP .
Earlier i used D2P setting.
Will try and report.
What gain setting are you using for your N3? Low, medium or high? Try changing the gain setting to Low and see if it solves the problem.First i connected N3 as source. output level from mojo was too high.
duetta
Anybody try swapping out the battery on a N3? Mine is beginning to run down pretty quickly (or quicker than I remembered...) and I saw that someone is selling a alleged replacement battery on Aliexpress. Anybody try doing this repair?
neoclassical
I have an intermittent left channel cut out in the headphone jack and the rewind button sometimes acts up as well. Is there a way to get these repaired? I'm assuming my warranty is out of date (I've owned it for 2 years).
TIA
TIA
@Andykong Does John from Caiyn take over service emails? I sent him an email and I wrote that I want to buy a motherboard for my N3 with USB problems and the jack plug
If you have channelled your request to service@cayin.cn already, that's the appropriate route for your request. There are several staff reading and responding through service@cayin.cn, depends on the product involved and nature of the problem.
But like trying to replace the main PCB of your old mobile phone, the cost of the PCB will likely exceed the market value of your mobile phone. That's how it works out in the consumer electronic industries.
TIA
If you want to submit your N3 for repair, you should go through your local dealer even when the DAP is out of warranty, the dealer are more familiar with the tax documentation for sending electronics in and out of China. If you do that yourselves, a simple mistake might cause hefty tax consequence like 20% of the ORIGINAL retail price. If your dealer is no longer available due to various reason, you can email service@cayin.cn for detail instruction.
actorlife
I'd just buy a used one. Not worth repairing like Andy said.
I like that it is good for transportation. I used it with my Dac / Amps via USB output. Now I use Hiby R2 for that. I will decide based on what price the motherboard hasI'd just buy a used one. Not worth repairing like Andy said.
I will say goodbye to him because he is no longer in stock
