svil3
- May 30, 2014
Bought it last october from ebay, specifically this seller:When and where did you buy it? If you use it by following user manual and don't drop it or hit it, normally this problem will never occur. hsilmi's issue indeed very wired.
https://www.ebay.com/itm/382076640928?ViewItem=&item=382076640928
It was new with the box sealed, everything works, even bluetooth connection and the battery duration and charge is fine, but if you shake gently the N3, you can feel how a "big" part inside is loose, as I said, I believe is the battery.
