Cayin N3 Hi-Res DAP with AKM4490 DAC, apt-X Bluetooth, and Line, USB & Coax Out for $150
Jul 16, 2017 at 3:06 PM Post #3,016 of 6,262
nifty, I'm curious to see why they choose a separate amp to handle the line out, rather than running straight from the dac output... or is that standard.
The data sheet for the AK4490 specifies that it has a variable adjustment to digital volume out, so why is there a need for a discrete amp for the line out function
Non the less, I'll be doing some line out comparisons later today, to see how that opAmp functions when I feed it through my pico power
I would assume the amp is to meet their requirements for output voltage and/or output impedance. I dunno. Cayin states line-out is 1V at 10K Ohms.
Jul 16, 2017 at 6:00 PM Post #3,017 of 6,262
Maybe it has to do with the LO being an optical out as well?
Jul 17, 2017 at 12:31 AM Post #3,018 of 6,262
Guys i noticed a problem with my cayin. I turned it off and charged it. About 4 or 5 hours later, its charged to 100 percent. I took the cable off. But then in the morning when i turned it on, its only 95%.
Jul 17, 2017 at 4:31 AM Post #3,019 of 6,262
I have the same issue today, i put some files (flac) on the sd card, it shows up on the sd card.
Once i put it on the N3, the folder is there but empty.
I tried on my hackintosh via 2 different usb cables, with a sd card reader, i even put the sd card in an android tablet to load the files and then transferred it in my N3...same issue
The flac files play just fine on my computer, but don't play on the tablet, nor appear on the N3.
Any idea? am i doing something wrong? it was working fine the first time i transferred some files, only thing that happened in between is the firmware upgrade to V.2.
Perhaps you guys that have had your N3 a little longer than me can shed some light on something for me. I went to find an album to listen to (Slipknot - .5 The Gray Chapter). However, this album did not show up using file browsing. Hooked the N3 up to my PC and the file and all of the tracks are showing up. Disconnect the N3 and the album is gone again. All other albums are showing within this folder. Hook the N3 back up to my PC and the file is there again. I delete it and put it back on the card with the same results of not showing on the N3. I hook it back up to my PC again and remove the .5 part from the folder name and it shows up and plays on the N3. I don't know if this is a known issue/bug or even if anyone else has had this happen to them. I don't have a lot of albums that start with a ( . ), but wonder if that was the problem?
Thanks
ETA: I went through and checked a couple other albums that have a number as the first character in the title and they all show up which leads me to believe the ( . ) is the culprit, but that seems weird to me.
I apologize for all the questions. I've been using FiiO's (X1, X1II, X3II, & X5II) for the past couple years for reference and never had this issue with them.
May I know what is the format of your card? Could you please try another cards? What is the sampling rate of your flac music files?Please note that N3 doesn't support 64kHZ sampling rate flac music files.
http://en.cayin.cn/
Jul 17, 2017 at 6:31 AM Post #3,020 of 6,262
It is in ex-fat, but i think the problem is simple: the sd card is faulty as i can't move anything on it.
I don't have a Windows pc to try from another source than my hackintosh (maybe it's the culprit), waiting for a new sd card reader to see if it comes from that.
(i quickly tested on a 2gb card and i can move files on it... so my 128gb sd card seems to be the problem, next week a new one will arrive and everything should be ok)
Thanks for your support Cayin :ok_hand:
Jul 17, 2017 at 8:45 AM Post #3,021 of 6,262
Hi guys, bit of a side topic update but we had our car in for it's service. We told them about the N3 connecting and not playing via Opel Intellilink. We also have had issues with Apple Carplay. They have fitted a new media system as apparently there's been a few issues and now everything works!
So happy to be able to use my N3 in the car now.
Jul 17, 2017 at 10:35 AM Post #3,022 of 6,262
My card is fine. It's exfat 200 gig Sandisk. I removed the "." from the beginning of the folder name and it appears. The folder contained a 320 but mp3 album.
Jul 17, 2017 at 10:35 PM Post #3,023 of 6,262
15 hours with the cayin have been a pleasure. I listen mostly mp3 and church podcast. I cant give technical comment but i can tell easily tell that this is better than my sansa clip. Im an amarteur who cant tell the difference between my 700 dollar home setup vs 5000 dollar setup. I feel there are potential if i upgrade my kz zst to somthing in the same price range as the n3.
Im curious if the battery is replaceable? How to open the battery compartment?
Hi, N3's battery is replaceable. But please note that customers need to mail it back to the factory for replacement or buy battery from Cayin and replace it by themselves. But according Air Law, for safety, we cannot only mail the lithium battery and must place it in the player for delivery. If they replace unauthorized battery on their own, it will void the warranty.
http://en.cayin.cn/
Jul 17, 2017 at 10:42 PM Post #3,024 of 6,262
Glad to hear that good news and we hope you can enjoy music with our products!:gs1000smile:
http://en.cayin.cn/
Jul 17, 2017 at 11:15 PM Post #3,025 of 6,262
Hi Guys my player currently is updated to v2, activated this screen lock setting but somehow it does not Lock the right side button on the player as mentioned in Cayin website .
Hi,please go to system setting->turn on Lock screen function, then please just turn off the N3 screen and try again.
http://en.cayin.cn/
Jul 17, 2017 at 11:19 PM Post #3,026 of 6,262
My Cyan Cayin N3 is on it's way. Always listened music on the HTC 10 which was OK.
Now with the U11 it's a step backwards. So a DAP is welcome then. Hope it will top a HTC 10. I guess it will.
Was planning to buy a Fiio X5II but after seeing and reading all the reviews. The N3 is the best bang for the buck.
And the HiBy feature looks like it's awesome, this way you can make it a streaming device in combination with the smartphone. Very clever. No need to pay 300 dollar+ to get Wifi capabilities.
Going to listen on the Momentum. And ordered the HD650 and Amp it with the Topping Nx4.
Can't wait until it arrives all.
:smiley:Haha, we also hope that you can enjoy music with Cayn N3!
http://en.cayin.cn/
Jul 18, 2017 at 1:50 AM Post #3,027 of 6,262
Except my nearest factory is in China, so I may as well buy a new N3 for the same price when my battery dies :p
Jul 18, 2017 at 4:07 AM Post #3,028 of 6,262
Ive downloaded the One from the anticipated beta that was posted here by Andy and then the one thats on the N3 new V2 firmware. None of them works on those 3 devices.
The HibyMusic app all close abruptly when connecting to the N3 via HibyLink.
If i dont turn on HibyLink on the N3 then i can connect to it as a bluetooth receiver from the same devices, so bluetooth is working on the N3 and on the android devices.
Thanks, will try to follow that thread also.
You can go to setting->Bluetooth, then click on the setting of Cayin N3, then forget this device and re-pair them to have a try.
http://en.cayin.cn/
Jul 18, 2017 at 4:26 AM Post #3,029 of 6,262
Announcement of Cayin N3 firmware v2.1
http://en.cayin.cn/download/show?id=13516
https://www.facebook.com/CayinAudio/posts/306479566429943
We tried our best to rectify the slow charging problem of N3 after the v2.0 firmware, sorry for all the inconvenient caused.
New Functions and System Optimization
  1. Calibrate Power management setting to rectify low charging current
  2. Rectify My favorite document cannot be removed through Quick Menu at specific operation sequence
  3. Remove the incorrect status display when playback multi-channel WAV document
Cayin N3 Firmware Upgrade
  • Each version of firmware might contain minor different, consumer please decide on your own accord whether you need to update the firmware of your N3 DAP.
  • Under normal circumstances, firmware upgrade will not cause any damage to user information, but Cayin cannot exclude the possibility of upgrade failure due to mal-operation or any other reason. For these reasons, you might be required to format your N3 DAP and result in losing person data stored on the player. We strongly suggest you backup all your personal data stored on the player before you perform firmware upgrade.
  • The N3 firmware cannot be used in other product, and the firmware from other product cannot be used in N3
Firmware upgrades procedure
  1. For safety reason, please make sure the N3 DAP has not less than 50% battery power before you proceed, otherwise please charge up the player before you upgrade the firmware
  2. Download the latest firmware from Cayin website (www.cayin.cn). Decompress and copy the N3 firmware file (update.upt) into the root directory of a TF card.
  3. Insert the TF card into the N3 DAP and complete your firmware upgrade with either one of the following steps:
    • While N3 has been turned on, select “System Setup” and scroll all the way to the bottom of the list, select “System Update”, the system will complete the upgrade process automatically, and reboot the player after update is completed.
    • While N3 has been turned off, hold the round physical “Enter” button, and then hold the “Power on/off” button, the system start the firmware upgrade process and will complete the process automatically. It will reboot the player after update is completed.
Note: N3 can support FAT/FAT32/exFAT/NTFS formatted TF card during the firmware upgrade process.
When the upgrade is completed, you can verify the current firmware version number by selecting “System Setting” menu, under “About the Player and storage information” option, check out the “Firmware Version” detail.
Attention
  • Do not operate the machine during firmware upgrade
  • Please delete/remove the firmware file from the TF card after firmware upgrade
  • Please update your Music Library after firmware upgrade
http://en.cayin.cn/
Jul 18, 2017 at 4:45 AM Post #3,030 of 6,262
I am waiting delivery of an N3. my intent is to use it as a wireless transport for my mojo. will hiby link allow me to do that? I am tired of wait for poly to become available and until it is I figured this might be a temporary alternative. Am I correct in my planning, or is there no way I can make it happen. the chain would be N3 tethered to mojo with hiby link handling the control duties.
last question... can I stream from my android device to mojo through the N3?
Hi, if your topology is cell phone))((N3--Mojo, yes, you can control mojo through the N3 with your android device.
http://en.cayin.cn/
