gken92
- Nov 2, 2016
I wonder if I should buy this instead of the LCD2C. For reference, i love bass. I love Fostex TH-X00's bass but i hate their sibilant highs and recessed mids.
Thanks for the info. Hopefully Campfire audio could provide some further information.PVD Beryllium is reported to be more brittle than rolled foil Beryllium (Utopia) so it should be noted for health reasons when discarding the headphone, or when damage occurs.
Checkout this thread:In my understanding, beryllium is toxic only during the processing process. It has been used for many speaker systems, and so far there is no health concern.
That being said, I understand that it's not an easy feeling that potential toxic material is so close to your body. What happens if the house gets fire or other hazardous condition?
Anyway, I'm enjoying the sound it produces...
Awesome! I need this too. Where did you buy those headband cushions?
i
I like the look! Wondering where you got the cushions as well
The headband cushion was a Sennheiser HD 580/600 replacement cushion from Amazon. The knit headband wrap is from Amazon as well. You’ll need to extend the earcups out 2-3 clicks to accommodate the extra padding.
Note, I got this cushion because it has a notch in the middle to alleviate pressure on the fibrous joint running along the top of the skull - I’m sensitive to pressure there and the Cascade is a little too much.
Use Velcro cable ties with the felt on the inside so as to not to scratch the Cascade’s headband padding and the rough side on the outside to stick to and keep the knit headband in place.
I hope this helps.
Comfort is a lot better!!! I can still feel the weight of the Cascade but it doesn’t hurt - I used the Cascade for 2+ hours last night without getting a hot spot.Hows the comfort now? I do get a little hotspot due to the headphones design
I wonder how 1MORE TRIPLE DRIVER compares to Cascade. Are there anyone who listen to both of them?
From the review from Innerfidelity, the 1MORE seems extremely travel friendly at 283g. (Cascade (383g)).
Both of them look well built and have sound for bass lovers. Both of them are slightly smaller than full over-ear closed cans.
Also, the price of the 1MORE is at a point difficult to resist, especially with a promo code (about $217)
For me the Cascade smoked the 2more at CanJam NYC. If memory serves me right they were only separated by the ibasso and maybe audio 64 booths and the Cascade was just on another level especially in the mids and highs. I also liked the Focal Listen pro better than the 1more.I wonder how 1MORE TRIPLE DRIVER compares to Cascade. Are there anyone who listen to both of them?
To put it briefly, this is what I wanted for about ten years. Freshly entering this headphone world, I liked the HD 25, and there is also a feeling that the feeling at the time when I was re-cableing was revived until I made overseas mail order.
What I was using when I started this blog is earphone ER 4, E 5, and headphones HD 25. Earphones have made long-term progress and have used countless models. But portable headphones have Edition 8 and T5p, but the feeling that I liked the HD 25 I felt at first was not so much renovated. I think that it was this CASCADE that I wanted to re-encode to HD 25 and get it to HD 25 - 13 and realize it. I wanted this until now. Earphone is a fierce battlefield, but portable headphones do not have much rival. What sound quality can be a competitor would be Edition 8 series or T5p.
Not at this moment. Balanced cables are optional.Are we gonna be able to purchase this with 2.5mm or 4.4mm balanced connector?
I mean as a combo, like you can chose which cable you want while purchasing, I won't be using the 3.5mm that comes standard with it since all my gear are balanced.
