Can you hear a difference between DAC's?
  • Total voters
    403
Aug 10, 2023 at 3:46 AM Post #571 of 613
Hey CofA, I'm rusty on this, but if there are measurable differences between 2 DACs, what happened to Bit Perfect?
Bitperfect is about delivering the signal to a specific address using a specific route without messing around along the way. Once the intended recipient gets that signal, it can and will do whatever it wants to it, anti-jitter/reclocking, oversampling, more or less digital filtering and perhaps some options turned on in the chip if the designer of the DAC wants to use them. Such as EQ or digital volume control.
Aug 10, 2023 at 4:43 AM Post #572 of 613
So here's the thing. If the circuitry can change the sound of a DAC, how is it possible that all DACs, with all kinds of circuitry, could sound the same, when this DAC alone can sound 2 different ways?
As it has an “Upsample” switch, I assume that when it’s switched off it is not up/over sampling, IE. It’s a NOS DAC. Since digital audio was first proposed nearly a century ago, a fundamental requirement is to bandlimit the signal to half the sampling rate, IE. To have an anti-alias filter when converting to digital and an anti-image filter when converting back to analogue. NOS DACs made in the last 20 years or so for the audiophile market often break this fundamental requirement. This results in certain issues, including a gradual high frequency roll-off starting around 2kHz and extending to 22.05kHz (in the case of a 44.1k sample rate), plus relatively high levels of ultrasonic artefacts (“images”), which are likely to cause IMD downstream. Both of these are within the audible spectrum and therefore many NOS DACs can be differentiated (by human hearing). When some say “all DACs” they obviously don’t include broken DACs, and NOS DACs can be described as “broken”, although deliberately “broken by design” rather than because some component has failed.
Are they perhaps related to the fact that the above measurements are related to specific aspects of the electrical signal while what we hear is a complex or a sum of aspects?
That’s certainly a major part of it, although there are also other factors. When we measure signals (analogue, digital or acoustic) we are obviously measuring the properties of those signals using absolute scales (decibels, Hertz, etc.) but human hearing typically does not perceive these absolute scales, it perceives different, relative scales. For example, the difference between say 100Hz and 200Hz is obviously 100Hz and is perceived as 1 octave, the difference between say 600Hz and 1,200Hz is obviously 600Hz, six times more than the previous 100Hz difference but it’s perceived exactly the same, a difference of 1 octave! Other perceptions are not directly related to an actual audio signal property but to a “complex sum of aspects” which also are not absolute. Our perception of “loudness” is a good example. Loudness is not a property of audio signals, it’s a perception which is a combination of properties (frequency and amplitude) but it’s not a straight “sum”, it’s more complex than that (involving an average of time and a transfer function). It seems that many audiophiles are commonly not aware of this basic fact. When we measure audio equipment/signals we obviously cannot measure human hearing perception because there isn’t any, audio equipment/signals do not have any human hearing perception.
But it’s easy to hear differences (for me and whisky agnostic) between two speakers, even the same speakers in two different rooms.
It ALL depends on the magnitude of the differences and where in the frequency spectrum they are. The same speakers in different rooms are going to produce numerous variations throughout the audible frequency spectrum and typically with swings of 20dB or more, due to room acoustics. Even cheap DACs are virtually ruler flat, any variations are in the least audible (or inaudible) frequency spectrum and typically the swings are less than 0.4dB.
It’s also very easy to hear differences between two masters which is where I’m spending my time (to find them) and money now.
Of course, there should always be audible “differences between two masters”. Why would a record label spend the time and money for a mastering engineer to make another master that sounds exactly the same as the master they’ve already paid for?
As I’ve seen other members mentioning it before, it is important to match levels between two devices under test, and it’s not always easy, as it should be below 0.2dB.
A match of 0.1dB or less is required scientifically. The problem is that a small difference in level is not perceived as a difference in level/loudness, it’s perceived as difference in sound quality, the louder one is usually perceived as “sounding better”. This is why there has been a “loudness war” for the last 60 years or so.
There will always be measurable differences between 2 DACs. In fact there will always be a measurable difference between exactly the same DAC, set identically and converting the exact same recording! The conversion process involves the application of dither (which results in white noise) and all analogue circuits introduce thermal noise (which is also a type of white noise). White noise is random amounts of all the frequencies (with certain statistical distributions) and because it has this random element it will always be different, even the same DAC set identically. This difference is minuscule and usually too low to even be resolved into sound (let alone be audible) but we can measure it.
G
Aug 10, 2023 at 6:18 AM Post #574 of 613
Rhetorical question indeed.
Why would I pay to buy something that I already own? Because a studio wants to make money and they tell me it’s better? :)
If I can agree that some initial masters had technical issues when converted to CD in the early 80s (for several technical reasons) I don’t agree to pay for something intentionally deviating from the original master, such as so many studios going loudness war. Others went as far as remixing, and I can’t say I liked that.
Indeed. I can’t tell the difference in ABX testing with below 0.2dB difference though.
Several devices I measured showed channel mismatch of 0.2dB, and outside ABX test I fail identifying them. But yeah .1dB is the target, .2dB being good enough I think.
Aug 10, 2023 at 6:21 AM Post #575 of 613
so much hate against loudness...
what music do you listen to when driving around in your car? Audiophile classical recordings?
Do you love music that makes use of 16bit dynamic range when you listen at 50-60dB(c) while having your morning coffee?
Aug 10, 2023 at 7:06 AM Post #576 of 613
Same piece, both on streaming services:
I've spend some time to listen to these using the RME ADI 2 dAC FS and an HD600.
I can't find anything wrong with either recording from my perspective as a consumer. The Brendel recording brings me closer to the piano, it sounds like sitting directly in front of the instrument. More intimate, more weight to the notes, more warmth.
In the Leotta recording the piano is further away from me, like sitting in the 5th row. There's more echo from the room and more space. Transients are fast and clear.
Soundstage is excellent with HD600 and both recordings.
I'd say these recordings are a bit different from each other.
I don't know anything about recording techniques and I might be totaly wrong.
Aug 10, 2023 at 8:32 AM Post #577 of 613
I have never tried any high end DACs but have tried the usual lower to mid range stiff, Schiit Modi, Modi Multibit, Mojo, Gryphon, Diablo etc all into the same several amplifiers and I can't hear any difference that I could not hand on heart say was more likely to be due entirely expectation bias.
Same here but haven't tried a really high-end DAC. Closest I get is Denafrips Ares II and I do think I can hear a difference between that and the rest of my stuff but barely. I still need to audition the DACs with speakers instead of HP's as well.
Aug 10, 2023 at 8:33 AM Post #578 of 613
Aug 10, 2023 at 9:24 AM Post #579 of 613
Four obvious pertinent questions then:
1. Which one do you think is the bad one and why? AND
2. How do you think a DAC could determine that? AND
3. Even if a DAC could determine that, how do you think it could make the bad recording sound like a good one?
4. Eelco Grimm discussed all manner of DAC developments over the years (filters, processing, noise-shaped dither and others) but didn’t even mention any of the previous questions, which is what you claim is the difference with high-end DACs. Is he wrong/misinformed and if so, why did you quote him in support of your claim?
Because you might want to hear a different mastering of it, maybe a cleaner version or one with better EQ or other processing. Incidentally, it has nothing to do with “a studio”, the decision to create/issue a new master can only be taken by the recording copyright holder, which is typically the record label.
If no one liked it, they wouldn’t have done it. A label will create a remix or remaster on the expectation that enough people will buy it to make a significant profit over the amount it cost to create, distribute and market it.
Yes, 0.7dB is considered a JND (Just Noticeable Difference) and around 0.5dB is the least difference that can generally be heard/differentiated. However, there are some conditions under which some people can hear a difference down to 0.3dB or even 0.2dB, which is why scientific validity requires 0.1dB or less.
G
Aug 10, 2023 at 9:34 AM Post #580 of 613
Are these really the same recording just remastered? They sound very different to me. The second seems to be very much closer to the piano. This is very noticeable on my speakers.
Edit: I see you just meant one was good the other bad…. Of course different player, different piano, different recording, different mastering.
FWIW I significantly prefer the Brendel version. It would be interesting to know if you consider that to be the good or bad version 😀
Edit2: interestingly I prefer the first recording on headphones. Same DAC. The first recording seems to have less dynamic range, possibly due to being mic’ed from farther away. I find it less jarring on the headphones. Just goes to show that everything after the DAC has more bearing on what you hear than the DAC and to some extent the music file itself.
Aug 10, 2023 at 10:02 AM Post #581 of 613
As far as I’m aware, he’s not claiming they’re different masters of the same recording. He seems to be claiming one is a bad recording while the other is a good recording and that a high-end DAC would make the bad recording sound “good”.
G
Aug 10, 2023 at 10:06 AM Post #582 of 613
G
Yes I belatedly got that.
As per my edits I preferred the first recording on headphone and the second on speakers. With the same DAC (Chord DAVE).
Love to find out which is supposedly the better recording.
Aug 10, 2023 at 10:15 AM Post #583 of 613
Yep, that’s because your Chord DAVE knew when you switched to listening on speakers and changed the bad (second) recording to make it sound better. That’s what high-end DACs do! Lol
G
Aug 10, 2023 at 10:58 AM Post #584 of 613
The Ares II has an option to operate in NOS mode, so there would be a slight but audible difference with other DACs. In default oversampling mode the artefacts are all well below audibility so you wouldn’t hear a difference, unless of course you compared it with a NOS or “tube” DAC.
Higher-end parts of the audiophile DAC market is a bit like higher-end parts of the Watch market, they both use a superseded technology and charge a lot more for them. Rolex for example rely on mechanical watch technology and Denafrips on R2R technology. The difference though is that Rolex (and similar companies) don’t claim their watches tell the time more accurately or in some way better than much cheaper mass produced digital watches, they sell on heritage/prestige/brand name, design, materials quality and the highest levels of hand-crafted workmanship.
G
Aug 10, 2023 at 12:27 PM Post #585 of 613
A plausible explanation is that the Brendel recordings are much earlier, they would almost certainly have been mixed/mastered on speakers, for playback on speakers. Because consumers extremely rarely used headphones. The Leotta recordings are far more recent, at a time when headphone use was very common, iPods/IEMs etc. So it’s far more likely the mix was checked on HPs and made to accommodate HP playback. A mix made on speakers for speakers will tend to be drier (have less reverb/echo) because the mix engineer/producer will be hearing the additional reverb of the studio control room and expect a similar addition of reverb from the consumers’ room. With HPs there is no additional reverb from the playback room/environment, so the mix requires more reverb to be added.
This also correlates to @paulrbarnard observations, although I stress that this is just an educated guess. For all I know, both recordings were made purely on speakers for speaker playback and that’s just how the engineers/producers/pianists wanted it to sound (on speakers).
G
