castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Bitperfect is typically used to talk about ASIO and WASAPI on the computer, which are the streaming options you pick to go from your audio player to the DAC. Once inside the DAC, all bets are off. And if we’re being rigorous, you could still manage to oversample, EQ, or change the volume before sending the result through ASIO if you really wanted it. Technically, the route to the DAC(ASIO) would still be called bitperfect as it only concerns the route. What goes on before, or after in the DAC, is a different story and the bit perfection is not in guaranteed anywhere else when you use ASIO(ironically, my current ASIO drivers oversample to the max the DAC can handle).I'm rusty on this. So both the regular output and the upsample to 192 output on that DAC are bitperfect?
Think of it as something similar to 'lossless' for an audio format. FLAC is lossless. But if I convert some 24/96.wav to 16/44 flac, is this lossless? Yet Brutus says FLAC is lossless, and sure, he is an honorable man.
DACs aren’t bit perfect. They make the signal analog for one. But even on the digital side, it would be a mistake by modern fidelity standards to apply no processing whatsoever (oversampling, noise shaping, some digital filtering and really anything that’s been found to help somewhere, like with jitter).
