And the cable is a very lightweight , and very soft , so very comfy to wear
Campfire - Solaris
- Thread starter KB
similar like u, all my balance cable is 4.4, assuming I will be long using AMP8... but the story is different... I have Fiio and custome adapter 4.4 to 2.5... but it add color and add weight... so prefer 2.5 terminate...Hi Fokta,
I prefer all my IEM cable is terminated with 2.5mm Balanced as I have adapter CA02 to convert to 4.4 balanced. With this approach, it can cater most of the port that DAP offer. At least for now.
I listened to my DX221 since May and I never feel want to swap to AMP 8 as I feel the sound is more details and layered, Yea, this is the sound I looking for. Until last week, my itchy hand replace AMP 1MKII to AMP8, Arrr... The details of the sound is not as par as MK II, but I get more bass. Just about 10 minutes of listening, I decided to swap back to AMP1 MKII.
Now waiting more review on AMP 9 and decide later going to buy or not.
Tips: Taobao store usually they selling AMP with 40 discount. Find those official seller from iBasso.
a college offered to try AMP8 mod. try it... still not my cup of tea...
for me, Solaris have to be pair with neutral DAP...
What kind of color do it add ?similar like u, all my balance cable is 4.4, assuming I will be long using AMP8... but the story is different... I have Fiio and custome adapter 4.4 to 2.5... but it add color and add weight... so prefer 2.5 terminate...
Im considering to buy these adapter too ...
just consider this adapter is additional Ohm... so some fell the bass is less punchy or the high seems smooth... but there's will be some song heard perfect... can be positive also negative...What kind of color do it add ?
The coloring is very small margin, but noticeable...
Example, like mine, I felt the bass is less punchy... not much different in rumble... IMO...
but despite the coloring... the adaptor is very usefull... I have 3 of these...
Okay , thanks . I think that’s okay , would be for my to go dapjust consider this adapter is additional Ohm... so some fell the bass is less punchy or the high seems smooth... but there's will be some song heard perfect... can be positive also negative...
zeroselect
Has anyone found a DAP that has no hiss with the Solaris? I was looking at picking up the Kann Cube if this was the case. Currently running a M11, its great but in quiet songs the hiss does bother me. The only dac/amp that I have that is truly silent is the RME ADI 2 DAC and using the ifi ie match on said M11. On my samsung S10+ is quiet as well.
Cowon plenue L , no hissHas anyone found a DAP that has no hiss with the Solaris? I was looking at picking up the Kann Cube if this was the case. Currently running a M11, its great but in quiet songs the hiss does bother me. The only dac/amp that I have that is truly silent is the RME ADI 2 DAC and using the ifi ie match on said M11. On my samsung S10+ is quiet as well.
Wildcatsare1
Or you could just pick up an iFi IEM Match, and keep your current DAP.
zeroselect
Already have the IEM match (both 3.5mm and 2.5mm). It alters the sound coming out.Or you could just pick up an iFi IEM Match, and keep your current DAP.
Wildcatsare1
It’s supposed to, for the better hopefully, sorry if your experience has been otherwise.
try the cowon u get the same dac as kann cube ( single not dual ) ,black background and sounds awesome with solaris especially with the new cable and 4.4. outAlready have the IEM match (both 3.5mm and 2.5mm). It alters the sound coming out.
you get better file support also try and love it
The sp1000 is great with Solaris. No hiss for me .
DX221 MK2... Waterfall Hiss... it will be unnoticeable when the song play...Has anyone found a DAP that has no hiss with the Solaris? I was looking at picking up the Kann Cube if this was the case. Currently running a M11, its great but in quiet songs the hiss does bother me. The only dac/amp that I have that is truly silent is the RME ADI 2 DAC and using the ifi ie match on said M11. On my samsung S10+ is quiet as well.
zero Hiss in even high Gain is LPGT... based on my exp.
AK also good in manage Hiss...
Yeah even the dx120 do hiss ...DX221 MK2... Waterfall Hiss... it will be unnoticeable when the song play...
I have a Sony NW-ZX300, and it has a very slight hiss. IEMatch on Ultra totally removes it from the 3.5. I usually listen on the 4.4 balanced but don't notice the hiss when playing anything. Both are on high gain in the settings.
Total: 17 (members: 0, guests: 17)
