Something arrived in the mail today
I never experienced with custom tips for universal before, it’s not totally as seamless as I would have thought to put those babies on... I actually had to insert the silicon tips first and then plug the Solaris bore into them. When you take them off, no way around it they will stay stuck and you’ll have to clumsily put them out
Second, as pointed by @Jackpot77 who also has them, the Solaris stick out quite a bit when wearing those so on the go is pretty much a no no I guess...
Now the sound!
It’s clear that you get a much better experience from a full custom seal, the first benefit is obviously isolation which is a step better and bass, yes the Solaris bass take on a new dimension with further detail texture wise and tad more bass impact as well. I need to spend more time but I am also convinced that soundstag and imaging are better as well. I need to spend time with them now and I’ll update my review in a few days.
Now I can imagine what the Solaris would be like in CIEM form and I must say I’d love to get them! (@KB please oh please we want a sequel to the Equinox !)
I find if you put them on to the IEM as normal, you should be able to insert them in a twisting / corkscrew motion just like inserting a CIEM. Taking them out is just a corkscrew in the opposite direction - haven't had a tip stick in my ear yet.
They give the best sound out of all my tips on the Solaris, and even though they stick out a little further, they stay rock solid in the ear when moving around, and even make the memory wire on the cable useful. Best €50 upgrade in the IEM world, in my humble opinion. They don't work well with all my IEMs that fit the nozzle, but for the Solaris they are superb.
Are they acrylic or silicone, by the way? I have the silicone ones.
