- Jan 30, 2011
I wouldn't worry about it - here's why
I mentioned it directly to Ken earlier - personally I can't wait to hear the Nova - the actual shape of the frequency response looks to be to be one of the best dual BA graphs I've seen.
- Our hearing is at its most sensitive from about 1-3 kHz, so you'll perceive those frequencies louder anyway.
- If you recheck the Nova graph you'll find that at 1 kHz - you could draw a straight line from 20-20K, and that's more likely to be your perceived average. So from that point, early upper mids (2-3 kHz) get a pretty small 2.5 dB bump, and then 3-4 kHz gets a pretty small 2.5 dB dip. It is all relative.
- The most important area for vocals - sometimes called the presence area - is from 1.5-2.5 kHz. This is often the area that needs a small rise to have cohesion between upper and lower mids, and gives sweetness in particular to female vocals. Nova ticks those boxes nicely.
- A number of very well regarded IEMs will have much bigger dips in the 3-4kHz area (relative to the 1-2 kHz zone) than the Nova, and this includes DUNU Titan 3 and 5, Noble's Savant, Jay's q-Jays, and CA's Orion (which is one of the best tuned single BA's I've ever heard). None of these IEMs lose any excitement or energy in their presentation.
I am concerned about the recession in the upper mids (around 3k) for the Nova. Can anybody confirm if it's an issue? I fear that it may remove some of the excitement and energy from the music and vocals in particular.
dB amplitude ratio
0 1
-3 0.708
-6 0.502
3dB down is enough for trained ears to detect it without direct AB comparison, 6dB down should be pretty obvious to anyone with sharp ears.
