carps
- Jun 27, 2016
Somehow I prefer EA Ares 2 over EA Thor 2. Sounds more natural to me. Not sure about the experience of others. (Andromeda SS driven by AK norma
Picked up the Andro S as a complement to my Katana. Seems almost redundant but I've been looking for something a little more musical to match the surgical Katana, without deviating from "neutrality".
I borrowed the silver Atlas cable from my local dealer for a week yo use with the Andro S.Hey, has anyone tried Andro with silver cable? What is your experience with that setup?
No problemo, thanks for sharing. But before you splurge a lot of dough on all sorts of accessories, keep in mind that the Andromeda are really sensitive to output impedance of the source and will sound:Yikes, sorry - I guess I am too excited about them that I ended up typing a lot lol.
.......Westone STAR Silicone Tips.........Seriously, it took 30 minutes of struggling to put them on. I even accidentally tore one of them while I was trying to stretch it to make it easier to put on. orz But wow was it worth it! I read so many threads and some people mentioned about having a super narrow stem? (sorry I really don't know what they're called) for wide bore IEMs will make everything sound compressed/narrow or something as well. Totally NOT true! It actually did just the opposite, it opened it right up, I heard a lot more details and everything sounded SO much better. Again, I am not sure if this is because of my ears but that's how it was like for me.
@candlejack I understand the difference with high Zout, but I confess that I don't understand why the Andros should sound bassy and congested with Zout< 1 ohm ... shouldn't a Zout as low as humanly possible be what all sources aspire to ?
I'm hardly the expert here, but as far as I understand, it has to do with the fact that the different drivers used in the Andromeda have drastically different FR as a function of Zout. If all drivers become equally quieter as Zout increases, then the overall signature of the headphone wouldn't change with Zout, but that's not the case with the Andromeda. [I looked for the measurements that support this, but couldn't find them]@candlejack I understand the difference with high Zout, but I confess that I don't understand why the Andros should sound bassy and congested with Zout< 1 ohm ... shouldn't a Zout as low as humanly possible be what all sources aspire to ?
I'm no sound science expert, but believe it's too do with the impedance curve of the bass drivers in the Andro. Lower impedance source gets more output from the particular bass BA being used, so keep pushing the Zout down and the bass keeps going up (and vice versa), leading to the difference in tuning.
Agree that most audiophile sources are aiming for <1 ohm these days, but this isn't always the case - the Shanling M2S has an output of between 4 and 5 ohms, for instance. I only know that as I used to own that and a 64 Audio U8 - the U8 was designed to work with "stage" sources used by musicians (typically carrying a much higher output impedance), and sounded bassier with typical sources but a lot leaner and less congested with the M2S, as this was producing the intended sound.
On a sidenote, I know 64 Audio adopted their LID technology to avoid these impedance curve issues in the current Tia lineup, so they now sound the same from all sources.
Apologies if you already knew all of that!
Andros's nominal impedance is 12.8 Ohm
