Ref 8 really does lift a veil vs the stock cable. I was shocked at the difference.
Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
- Jun 22, 2015
SXC 8 is even better as it improves the bass and details.
Dr. Manhattan
I bought the green Andros in-store a month ago and they came with the updated nozzles. I’ll edit this post with pics when I have time.
I talked to CA rep and here is their response
Actually, the length has not changed - there is now a step - which makes the nozzle appear longer.
The main difference is material. The nozzle is now stainless steel as opposed to aluminum.
The step is part of the process of machining the stainless steel.
The change was implemented on the Andromeda CK Pacific Blue Edition in Dec '17, followed by all production Andromeda.
Hope that helps, let me know if you have any other questions. Thanks!
Around what Serial did that start? Thanks.
I’m not sure. Maybe someone who bought their Andromedas in December can chime in.Around what Serial did that start? Thanks.
I am actually looking to buy some andros or Westone W80 but they’re hard to find used for the right price for me.
W80’s whole package and comfort are much better but the same cheap plastic housing bothers me for a $1500 iem. Same plastic they use in their $199 W10 where as my CA L2 are made amazing and love the stock Litz cable because zero microphonics.
Just got an ifi xdsd anyone have any experience if that is a good pair for the sensitive Andromedas? Or do I just need to add an iematch
- Oct 20, 2016
Can you share the instructions?
I took the memory wire out of my ALO Audio SXC-8 cable (thanks lookout57 for instructions)
Now it sits across my ears very well with the Andromeda.
Here.
http://www.headpie.net/2018/06/alo-audio-sxc-8-mod-like-surgeon.html?m=1
Compiled with pictures
Thanks to @Lookout57
I gave the Andromedas a day's listen with the iEMatch from the Lightning-to-3.5mm dongle, which has a <1-ohm output impedance, both with and without a 20-ohm impedance adapter in between. My conclusion is that when using the 1-ohm Ultra setting, the Andromedas sound more natural, with the mids being fuller, with the impedance adapter than without. Vocals in particular are more pleasant to the ear. Cymbals do sound somewhat less crisp with the 20-ohm, but I think that's because the iEMatch by itself makes the Andromedas sound thinner in general, exposing more of the treble.
On the 2.5-ohm High setting, the difference is subtler due to the OI making the Andromedas sounding leaner anyway, but it is nevertheless there. The brighter sound from the iEMatch alone may still be preferred by some at 2.5 ohms as it generates the perception of slightly wider soundstage.
I've had similar results from other portable sources. Overall, I would say that the Andromedas remain more faithful to their original tuning when used with both the iEMatch and an impedance adapter. I've been told by someone who makes volume attenuators that they need to be used with high-OI amps for proper load impedance matching, and I believe that this holds true for the iEMatch as well.
Just as with the UE Buffer Jack, if you're dissatisfied with the way the iEMatch sounds on its own, I would suggest pairing it with the 20-ohm, even if it means having three dongles dangling from your phone. You may want to use an L-shaped 3.5mm extension adapter instead of plugging the 20-ohm directly into a device's headphone jack, as the solder inside can break off if the tip is bent.
Edit: So this is what the ideal "portable" setup for the Andromedas looks like:
pikachuchu
Ahhhh Can’t wait to read impressions! Doesn't Andromeda has SpinFit eartip in the box too?
Impressions of Andromeda?Ahhhh Can’t wait to read impressions! Doesn't Andromeda has SpinFit eartip in the box too?
mottykytu
- Feb 16, 2014
How does the Andromeda Compare to Noble K10 my friends?
SciOC
Random question, if I want to buy a new pair of the Andromeda, are there ever sales on them or just when ALO is selling b-stock? I want to know if there is any point in waiting for a lower price or sale or if I should just pull the trigger and enjoy them.
MarkF786
Any reason why an inline passive volume control (ie. a potentiometer) wouldn't be able to do the same thing as the IEMatch, though infinitely variable?
I imagine the IEMatch just contains two selectable resistors.
You can DIY a voltage divider for the Andromedas with a potentiometer in place of a fixed-ohm resistor, and people have done so. As with most things, you're paying to have someone else make it for you.Any reason why an inline passive volume control (ie. a potentiometer) wouldn't be able to do the same thing as the IEMatch, though infinitely variable?
A simple inline resistor wouldn't do enough to reduce signal noise, which is the greatest problem when matching sources to the Andromeda, unless you set the resistance high enough to mangle the frequency response.
Edit: If you aren't awful at soldering like I am, you can make an adapter for cheap with instructions found here: https://diyaudioheaven.wordpress.com/headphones/headphone-attenuation-adapter/
I'm assuming IFI did not add resistors between the divider circuit and plug as they should have for an all-purpose adapter.
Total: 7 (members: 0, guests: 7)
