blazinblazin
- Nov 19, 2015
I read one is going to be discontinued and replaced by Polaris.
Well now I see where you're looking. I wasn't on CA's direct site. They're still in stock on ALO's site for anyone who wants them: https://www.aloaudio.com/shop/nova/Are you sure? They are no longer listed on their site: https://campfireaudio.com/
Also, spoke to an authorized dealer who is clearing stock and he said they didnt really tell them anything but they aren’t available.
I don't see how that would be the Nova though, unless they're gonna tag the Polaris with the Nova's price tag cuz the Polaris costs $100 more than what the Nova has been listed at.I read one is going to be discontinued and replaced by Polaris.
They are picky but I tried them on the AK70 and the SP1000 and I had no issues with both!I'm considering purchasing a pair of Andromedas to use with my AK380 duralamin, has anyone had the opportunity to listen to this combination perhaps? I've read the Andromedas can be quite picky when it comes to sources.
Depends on the impedance difference between the stock to Ref 8 cable. There are several variables that can change what is heard out of the Andromeda, and one main aspect in regards to the frequency response is the impedance added between the source and the drivers. The other is the tips, bore sizing and the material type(silicone, foam, etc..).So I've been using the Ref 8 with Andro for the past few days and wow, the improvement vs stock is more noticeable than I expected. I feel it added more bass impact and also treble clarity. Anyone else using this combo and agree or am I crazy?
On the other hand, someone here did mention it was microphonic and I agree, noticeably more so than the stock Litz and also stiffer but I can live with it because it sounds amazing.
I wonder how similarly priced cables from EA, Norne, PWA, etc would compare to the Ref 8.
It's difficult to make Andro sound dark(to the opposite, it's easier to make it sound leaner and brighter), and Mojo provides greater warmth, but not the kind that messes the mids. Andro works well with Mojo, so no worries.
When you look at bass on a graph, the incline toward sub bass in a close to linear fashion doesn't blead to the mids. I guess we refer to them as L response, but it's more obtuse than a strict L.
I guess with a bit of teble boost, it's closer to a V sig? But, to me mids arn't like what you expect out of a V sig.
Sonically, it's more of an L sig.
This is awesome--thanks for showing.
I have the Litz cable terminated in the 3.5 right angle plug, and the Litz Lightning cable for the iPhone. The Lightning cable definitely has a lower Z, as the increase in bass is quite noticeable. So much so that I had to change the tips I used to get the same sound as I had before. I currently use JVC Spiral Dots and they give me the best balance--tuned to reference with some low end warmth.
