Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
Oct 27, 2017 at 2:53 PM Post #4,531 of 9,829
Careful. I was scolded by a mod in another thread for even suggesting that a cable of similar resistance may change the sound. This was not in the proof required sound science forum.
You weren’t scolded - I simply asked the manner of you conducting the comparison. And I’m not a Mod anymore, and was simply asking a question. Why is it when someone simply asks for more information when cable claims are made, some people get so defensive?
Oct 27, 2017 at 3:03 PM Post #4,532 of 9,829
Is there a big upgrade buying the official reference cable of the Andromeda? Or is it a waste of money?
You can always ask the seller to demo one and if it doesn't make a difference or it makes a difference, but not what you expect, then return it and go back to SPC Litz stock cable.
Oct 27, 2017 at 3:56 PM Post #4,533 of 9,829
I wasn’t referring to you. No prob there at all. It’s not the sound science forum and something stated as being subject to opinion in the original post shouldn’t require a technical defense(ive). Prove it or shut up is not appreciated. I’m done if you are.
Oct 27, 2017 at 4:06 PM Post #4,534 of 9,829
My apologies :wink:
And actually the Andromeda is one of the few which may very well change frequency response with cable dues to impedance changes but it will depend on the cable.
Oct 27, 2017 at 4:24 PM Post #4,535 of 9,829
My apologies :wink:
We good. I made some posts about that. I came up with 3.9 ohms added as my preference with a very low z source. I get it.
Oct 27, 2017 at 4:30 PM Post #4,536 of 9,829
Have you tried many of the other CA IEMs? I didn't have the means to test the Orion or Nova for propensity to impedance changes during the tours (something I can do now - but sadly don't have access to the IEMs)
Oct 27, 2017 at 4:49 PM Post #4,537 of 9,829
I like a balanced sound so andro and orion are my favs for awesome valueness.
Oct 27, 2017 at 8:16 PM Post #4,539 of 9,829
Anyone using Ref 8 cable w/ Andro? Is it a solid improvement from stock?
There's improvements but is it solid enough for you. I cannot comment.
I remember there are a few Ref 8 cable reviews around if you google.
Oct 27, 2017 at 8:46 PM Post #4,540 of 9,829
I managed to remove the memory wire and heat shrink off the Litz cable today. It was a painstakingly tedious job, but oh was it worth it, fit and comfort now is top-notch! Not sure why I waited so long to do this, just cowhearted I guess...
Oct 27, 2017 at 8:57 PM Post #4,541 of 9,829
I’m having a strange issue where there is a crinkling/ crackling sound from only the left earpiece. It happens when I move my head with and without cable attached, with different tips as well. I can also hear a distortion at certain parts of songs reliably from the earphone that is not present in my other headphones. My guess is a ba driver is loose/ broken. Has anyone else experienced this?
Oct 28, 2017 at 2:13 PM Post #4,543 of 9,829
Just started happening to mine over the last week or so (my experience is almost exactly the same as yours, down to the left earpiece), and it persists over multiple sources. Could it be a problem with the MMCX connectors? It would be really good to know what the likely cause is since I love my andros and want to keep them alive and well.
Oct 28, 2017 at 8:47 PM Post #4,545 of 9,829
I bought it during a sale and to my ears the audio sounded a bit clearer and slightly more open. Not a $200 difference though and it's microphonic as hell compared to the stock cable
