ubs28
- Aug 2, 2013
Which tips give the best sound by the way? I am currently using the included spintfits tips.
Should also give spiral dot tips a try tooWhich tips give the best sound by the way? I am currently using the included spintfits tips.
Maybe you want to give Symbio MandarinEs tips a try
Spiral dots or Above comply both work very well.Spintips made it sound a bit thin for me. I ended up sticking with the Comply TX400/TSX400. Similar sound to the foam ones that CA includes, but the waxguard is a nice extra. Protects those big open nozzles.
I think it's more fit than anything with the spiral dots for me. I like the acoustic foam that @Hi-Fi'er shows below. Where would one find that acoustic foam?I tried SpiralDots but didn't find them to sound much different from the Spinfits with the Andromeda. That was right when I got it tho, maybe I'll have another go now to check it out.
Yeah! cables without memory wire are much better for me ergonomically.I removed the stupid wires in the cables. Way better fit now and way more comfortable.
