PhoenixG
- Nov 4, 2012
On my vintage equipment I will also scrub the prongs of the AC plugs if they are brass. Again, very little investment for peace of mind.
That's actually something I was going to discuss as well. You can get some increased performance from that if there is a permissivity issue (mediocre connection to wall power). It is a smaller scale problem since most amps have stuff between the socket and the fuse, like a transformer, possibly capacitor bonding (on two prong amps), and chokes. Cleaning the AC prongs is a real thing. If you have a dedicated power source that provides clean AC, why not make it a good connection. I think that does more than ANY boutique power cable when the original cable is a) appropriately spec'd and b) not corroded or damaged.
Ok, part two, fuses IN the signal path.
While it is unusual to see a fuse in the signal path of most amps, it does sometimes happen. The question is, does a boutique fuse matter here either? Well, it depends where it is. If the fuse is before the output, no. No way. Keep it clean and replace them if they pop or warp, but long story short, not they don't.
After the output, I will be honest, it is possible to have a difference. Some boutique fuses are sliiiiightly lower impedance than their cheapo bretheren. I'm talking fractions of an ohm. Why does that matter? Damping factor. Any good salesman will tell you that their amp has a damping factor of a kazillion. Bigger is better right? Well that number can get HUGE! A billion? Sure! But my amp has a trillion, so there! The way you get that is dividing the impedance of a speaker (8 ohmn nominal) by the internal impedance of your output (typically as low as possible). If your output fuse is .0001 ohms and the boutique fuse is .00005 ohms, your damping factor just jumped by a factor of twenty. WOOHOO!
But does it matter? Ehhhhhhhh, I won't say it does. Pretty much anything above 20 is the same, especially since most people have a wire in the mix and not just speakers welded to the amp output. For you head phone guys, your damping factor can actually invert on a vintage amp. If you have low impedance cans hooked up to a mega-amp with dropping resistors, you can easily get below one. Silent One with with his Sansui G22000 Probably has 500 ohm dropping resistors in there to keep from blowing up a 32 ohm can.The nominal damping factor on that setup is tiny. Granted, it moves closer to one with his high impedance cans. You can debate it all day and not find any correlation between damping factor and quality.
Two more paragraphs and I swear I'll be done.
OK, so where can a fuse make the most difference? If you guessed in a speaker, you'd be right! It is common to have fuses right in the input of speakers. Endemic. And nobody ever checks them. Like, ever. I've bought probably a half dozen "dead on arrival"/"Parts only" speakers that just had a blown fuse. Great deal for me, but they could have checked. Also, those suckers are always dirty. They sit on the floor and move air around. Think how dirty your AC unit would be after 50 years without a filter. If you want to spend some money on a boutique fuse, do it there. Boutique fuses are slightly nicer quality and don't corrode if they're gold plated. Also, speaker fuses are the *most* likely to have been run really hot and warp. When I get a new pair of speakers, I always clean every contact in them. Fuses and brackets, driver connectors, and L-pads. If you want an infinite return on investment for your ears, do yourself that favor. But I digress.
So why do people swear by boutique fuses? Let's not debate the quality. Gold plated is pretty sweet, let's be honest. Look closer though. They come with a polishing cloth and instructions to CLEAN the fuse and bracket. So there's the biggest gainer right there. If you were to pop a squeaky clean five cent fuse right in there after cleaning the bracket, I'd bet it sounded pretty good too. It might need to be replaced one or two extra times in its life if you live in a humid area though, but that's it. Also, marketing can be pretty strong stuff and they are packed full of it. If you are told your music is better, then you'd probably believe it. I dare you to put it to a blind test and see if you can tell the difference.
