Mach-X
- Feb 6, 2013
I've found the best headphone out is when I wired a headphone extension cable directly to the speaker outs. Effortless power, high s/n.
Picked up a Marantz 4270 on craigslist with wood case. This thing is just about mint condition on the inside and out.
Finally a break for you! Congrats!
With some of us it's simply because we can.
... - if you EVER monitored real music off some really good recording on an oscilloscope ( comparing the input to the power amp with its output ) , you would quickly learn you can (almost - except with super efficient speakers ) NEVER have enough, let alone too much power. Whether the speakers can use it to convert to sound without selfdestructing is yet another matter ...
The peaks that are short enough in duration for humans not to be able to discern them as clipped/distorted
can exceed what we think is "perfect" - by 6 and more dBs ... Setting the volume so that an amp is always within its clipping capabilities will generally produce too low listening level. ( basically, the same thing as loudness wars in mastering of the CDs these days )
That is why tube amplification manufacturers are boasting "their" watts are more "powerful" than transistor variety.
When clipped, tubes behave in much more benign way than transistors - yielding resulting distortion audibly lower. For this distortion during the overload to remain approximately comparable, a transistor amp has to be much more powerful than the tube one - at least twice, preferably 4 times.
100 W tube amps are reasonably common - 400 W good sounding trannies are scarce. Monster Pioneer receivers on this thread do come close...
I've monitored real music over the years in studios but never with an oscilloscope; wasn't my aim at the time. Your example sounds a lot like the analogy of cars, motors, horsepower and torque converters. Give me your biggest baddest motor but if you can't efficiently convert it and put it on the ground, well...
To be clear, I wasn't making a case for having enough or way too much power to drive headphones. Rather, that some of us already have the quantity of power we do in-house and chose to drive our HE-6 with 'em. And we got enough to handle it!But I do understand where you're coming from.
For me it's a matter of 'why not?' With 64 ohm headphones I still get reasonable range on the volume dial, so why not use ALL the capability of the amp instead of a cutdown version
