BmWr75
- Jun 20, 2008
Thanks. That one electronics course in college has come in handy over the years.
Ha!!!!! Non of my courses have come in handy. Lol
Originally Posted by Rawrbington /img/forum/go_quote.gif
thats a great lookin Sony you got there Shmitty!
too bad modern stuff doesn't look half as sexty
You're looking at it all wrong. Putting a 220ohm resistor at the headphone out doesn't make the output impedance 220ohms. It's just for lowering the gain since the headphone out is derived from the speaker taps. Actually, if they used a value higher than that, it would be a better match for 32ohm grados. If they only used a 32ohm resistor, grados would be fried. For example if the amp had a power rating of 80wpc at 8ohm, then with the 220ohm resistors the output would still be 2.5-3 full watts which is plenty for anything short an he-6 and grados would probably hiss like crazy without an additional -20db button.
My fisher tube integrated used 330ohm resistors at the headphone out and the speaker out wpc is only 25watts, and the headphone out was still plenty powerful the drive most headphones. But I did swap them out with lower ohm resistors to drive a pair of he-5's I use to have. But I may put the 330ohms back in since I won't be powering anything like that out of the headphone out anymore.
Ohm's Law is V = I * R, where V = voltage, I = amperage and R = resistance
or I = V / R is another way to state Ohm's Law.
Then, another useful equation is: Power (P) = V * I
So, P = V-squared / R if you substitute V / R for I in the equation above.
Let's now do the math on your receiver's headphone jack output.. Your receiver is rated to put out 45 watts (Power) at a load of 8 ohms (resistance) via the speaker outputs. V-squared = 45 watts * 8 ohms, so V = 19 volts
Now we can calculate the Power output at the headphone jack using V = 19 volts and R = 220 ohms
P = (19*19)/220 = 1.6 watts at the headphone jack.
If I've messed this up, somebody speak up.
The output impedance of the CR-640 power amp ICs into a speaker is less than one ohm.
Yamaha then puts a 220 ohm resisitor in series between the power amp and the headphone jack.
This makes the output impedance at the headphone jacks approx. 220 ohms.
It doesn't alter the gain of the amp, it attentuates the signal from the power amp.
The reason why there are four resistors are:
two for each headphone jack
there are two for each headphone jack as one is for right channel, the other is for left channel.
However, you certainly are correct: the 220 ohm resistor limits the output to a 32 ohm Grado.
Historically, when the CR-640s were released, most headphones were 600 ohms or higher, for example, I used to use a 2,000 can with my CR-2020.
I calculated a few examples below:
220 ohms goes a long way towards protecting various value cans from frying. (Slaps forehead!) So there is a point to having a large output impedance on this amp. (slaps forehead again!)
The math and formulas are absolutely correct, but we also need to take into account that the 220 ohm is in series with the headphone, so the headphone will get less than 1.6 Watts at clipping.
If we continue to use your 45 Watt amp example, and use some voltage divider math:
For example, for a 32 ohm Grado:
V = 19 * 32/(220+32)
= 2.41 Volts
P = (2.41 * 2.41)/32
= 182 milliWatts
For LSD, 60 ohms
V = 19 * 60/(60 + 220)
= 4.07 Volts
P = (4.07 * 4.07)/60
= 276 milliWatts
For a 600 ohm Beyer:
V = 19 * 600/(220 + 600)
= 13.9 Volts
P = (13.9 * 13.9)/600
= 322 milliWatts
For 2,000 ohm 'phones:
V = 19 * 2000/(2000 + 220)
= 17,2 Volts
P = 17.2 * 17.2 / 2000
= 146 milliWatts
so should be able to drive the LCD-2 to ear bleeding volume.
you may need to lower the headphone jack impedance to drive HiFi Man HE-6, see Moodryn's post above.
however the headphone jack impedance is very high if that kind of thing concerns you......i.e. a headphone which needs a high damping factor and/or has an impedance which varies with frequency.
Oooops, I almost forgot......Happy New Year!
When I had my LCD-2's plugged into my CR-2020, I couldn't get the volume level to 1. It was just too loud. Same thing with the HD800.
I will resist the impulse to ask you if the volume control went to 11!
Did you try pushing in the "Audio Muting" button? It reduces output by -20 dB which is significant!
The only other thing I can add to this is that 25-30 years ago my brother and I had:
1 pair of Sennheiser HD424
1 pair of AKG K241
1 pair of Koss headphones that looked kind of like Grados, they had a volume control on each ear!
We would often listen to music at the same time thru the two headphone jacks late at night.
We never had any problems with excessive volume or getting the right volume with any of those cans.
Good idea...
Loudness set to 10 (off), Audio Muting -20 db, Volume is now at 2 (out of 10).
Thanks!
