5aces
- Nov 11, 2009
Do you find that using the 20 db mute takes away some of the fidelity? When Driving my HE-6's through the speaker taps of the AU-717 if I use the 20 db muting I think it slightly reduces the impact of the lows
Is Sansui AU 717 still giving you a perception of less bass impact when the mute switch is engaged?
Most of these mute switches introduce a resistor into the circuit to get the volume down.
Generally,resistors shouldn't drift out of spec and will either pass current or not,you could take a look for your own satisfaction.
I know with some Sansui models you get a lot of volume early on the volume control,nice for speakers but not so much for headphones.
The mute switch will provide more flexibility of graduations on volume knob for some headphones.
Bass is a big part of modern music and most people need a specific amount to satisfy their sense.
For an experiment,dial back the bass on the tone control and kick in the loudness contour-see if you like that on -20db,one never knows it may be the in between setting you are seeking...
None of my current Sansui amps has the loudness switch to try but the CA preamplifier has a 150-300-600 Hz selector to augment dialing in the bass.
