how's everybody doing here, on the vintage amplifier / receiver forum?
my Technics SA-500 has a couple of issues that will put it in for service. there is some "scratchiness" in the volume pot (that hasn't responded to a couple of applications of compressed air and contact cleaner). when I go to make a fine adjustment to the volume, I noticed today that a "pop" will be heard in the left speaker when moving the volume knob within that certain spot. hopefully, the volume control mechanism can be dis-assembled, cleaned, and then put back together (re-soldered back on?) if necessary.
the other area of concern has to do with the balance between left and right. and, this seems to be more noticeable with headphones rather than with the speakers engaged. there seems to be less output on the left channel. (which hints at the output transistor(s) in the left channel needing replacement).
i'm happy with the overall sound quality that this receiver delivers, but I thought it would be a good time for the tech to do some other maintenance work, while he's at it.
any thoughts as to any pitfalls to avoid or what should definitely be done at this time to this unit, before any specific work is ordered? (many are probably thinking: "replace the caps." yes. but with what type? in other words, should I go with anything other than OEM?) as far as I know, no work has ever been done to this receiver. (nor has anything ever been done to my SONY STR-6055).
this speaks to the original build-quality of these pieces. these two receivers that I own could've come with a 40-year parts warranty!
