fewtch
- Jul 23, 2003
I can't prove anything, but will simply submit this for consideration: "Wire is wire." It conducts electricity, and aside from shielding differences (helping eliminate RFI/EMI) I see nothing in electronics or science to explain why one cable would sound "dramatically" different than another.
Given that, would you be willing to call it mysticism? What else could it reasonably be called?
There are cable believers and cable non-believers... fair enough from here, many people believe in God as well and that can't be proven either. I don't much care for it when believers insist theirs is the absolute factual viewpoint and "I challenge you to compare these two high-end cables" blah blah... a similar challenge can be offered by the non-believer side: Do some controlled double-blind comparisons on those same cables and see if you can still tell them apart.
Anyway, it's pointless to continue with this... arspy87 has certainly heard the two viewpoints and can decide for him/herself.
P.S. one question from arspy87 I can answer...
At audio frequencies and headphone wattage, internal resistance differences should be insignificant. You may get a contradictory opinion tho, seems absolutely nothing is set in stone around here
Originally Posted by some1x If you can prove that the Silver Dragon is made with the same formula as Sennheiser HD650 stock cable, I'll admit that the differences I heard between them to be simply placebo effect |
Are there also significant differences in the internal resistance of different types of wire? |
