purk
- Sep 26, 2001
Not really. Personally, I will stop with the cable upgrade and will not go any further because I already have excellent sources and amps. However, everyone preference is difference; therefore, if Azure feels that he still need more bass...he might can turn to Larry as a last resort. I was very surprised at how much you like your heavily modded CD3000, which is good for you. OTOH, I found the cable makes bigger difference than cups. The orinal cups were tuned for that drivers. By changing the housing properties, you will change the sound character of the headphones. OTOH, you can enhnace all the good qualities by just using a better cable. By using R10-size cups on the CD3000 will not make it an R10. You should really get a stock CD3000 and compare them with your heavily modded CD3000 side by side and tell me what you think.
Interesting you recommend the R10 driver housings, even if as a last resort. Are you saying that if he were to receive his PPA and recable his CD3000, yet still crave more bass and impact that the Headphile mod could possibly provide him with it? |
