Azure
- Jun 13, 2004
[I posted this in the Headphones forum because it applies to BOTH sources and headphone amplifiers, and I figured that this would then be the best place to post this]
My CD3000 came in on Monday, and I'm loving it. Very fast, clean, detailed, and has a supernatural-sized soundstage (all wrapped up in a mighty comfy headphone!). Unfortunately, my source and amp is the Benchmark DAC1, which has resulted in a lean, bright sound. Comparing my CD3000 to my DT990, I really admire the DT990's bass power/volume and more controlled highs. So, the DAC1 is going to have to go, and I'm now in the market for a new DAC/amp. I'm looking for the following:
-Increased bass volume & slam (I want to add WEIGHT to the music; I'd really like the CD3000 bass to sound/feel a bit more like the DT990 bass, if possible)
-Smooth, non-fatiguing highs (I don't want the CD3000 to have recessed highs, but I don't want them to be anywhere near as fatiguing as they currently are with my DAC1)
-Airy with a large soundstage (I don't want anything that sounds "in-your-face" a la Grados. I love air and soundstage; the more the better!)
Budget is $900 MAX (I would strongly prefer to spend less than that). Here's what I've been looking at:
Source:
Apogee Mini-DAC (non-USB)
CI Audio VDA-2
Lavry DA10
Music Fidelity X-DAC v3
Stello DA100 (Would require finding a used DA100, which can be difficult...)
Zapfiltered Zhaolu
Amp:
Corda HeadFive (I am curious about cross-feed...)
Darkvoice THA336i
Woo Audio 3(+)/6
PPA (Diamond buffer, variable bass boost, OPA627/637, STEPS)
Singlepower PPX3 (MAYBE SLAM, if I can find a good deal)
Stello HP100 (Filter B)
X-CAN v3
As you can see, I'm having a tough time narrowing it down (especially considering all the mixing and matching that can be done). Woody may be an option, if Larry still offers the service; do consider the cost of woodying a CD3000, though. Would a different headphone be a better solution, perhaps? Any help is much appreciated
Source:
CI Audio VDA-2
Lavry DA10
Zapfiltered Zhaolu
Amp:
Darkvoice THA336i
Woo Audio 3(+)/6
X-CAN v3
