Brainwavz Audio B400 4-Way Quad Driver 3D Printed IEM
8 9 10 11 12 13 14 15 16 17
19 20 21 22 23 24 25 26 27 28
  1. addictedflyer
    Does anyone know how does the B400 stack up to Audio Technica’s IM02? I quite like the sound signature of the IM02 and am in the market for a new pair of headphones now..
    With the B400 at a comparable price, it seems like a good replacement.
    Badder likes this.
  2. maniac2003
    @razzer001 How is the driver built-up on the B400?
    2 low, 1 mid and 1 high?
  3. Brooko Contributor
    1 low, 2 mids, 1 high.
    leobigfield, maniac2003 and Ahmad313 like this.
  4. griff06
    When might the review available @Brooko?
    Looking forward to your thoughts.
    Many thanks
  5. fixxxer667
    Quick question to the wonderfully responsive brainwavz team:
    Any plans for a 3.5 mm mmcx cable with inline mic / controls?
    If not, any recommendations on that end? E.g., would the Shure cbl-m+-k or more recent rmce cables that have the Shure SE mmcx connectors work?
  6. griff06
  7. DecentLevi
    He's feeling a bit ill and swamped. I'll also do a review after some weeks.
  8. griff06
    Reviewers are not allowed to be ill i thought? Joking of course. Hope you feel better soon @Brooko!
    Yea your thoughts would be most welcome... pretty sure ill get these but Cardas A8 was another option or LZ A4, UPQ QE80, 1more quad or Dunu 2002.. there was about 15 on my shortlist but lost the flippin notebook.
    Cheers
  9. HiFiChris Contributor
    The Shure microphone + remote cable would fit but is unfortunately not of the highest quality (the remote unit is unnecessarily large, the cable below the y-splitter does not appear as sturdy as with the regular cable, the straight 3.5 mm plug appears like a weak spot with minimal Apple-like strain relief).
    I don't know if it's still available somewhere, but the Logitech Ultimate Ears UE900/UE900S microphone cable would be a great choice for a cable that isn't only high quality but also inexpensive ($20-ish).
    fixxxer667 likes this.
  10. razzer001 Contributor
    Yes we do, the in-line remote cable maybe ready around the start of November, they will look like our other standard MMCX cables with some changes to the design of the plug and splitter. The remote & mic will be compatible with iOS and most android phones.
    Brainwavz Audio Earphones | Headphones | Accessories Stay updated on Brainwavz Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/brainwavzaudio https://twitter.com/brainwavzaudio https://www.instagram.com/brainwavzaudio/ https://www.brainwavzaudio.com help@yourbrainwavz.com https://www.brainwavzaudio.com
    fixxxer667 and Ahmad313 like this.
  11. fixxxer667
    razzer001: Excellent, that's good to hear :)
    As per HiFiChris' comment (thanks!), I've had to replace the Shure CBL-M-K cables three times within a 2y period, and original UE900 cables are currently nigh impossible to find in EU, so that would only leave us hoping the new RMCE Shure cable has improved :)
    In any case, looking forward to the "official" mic cable option, looks like this is making my Xmas self-gift list, hope the HEAD-FI discount lasts till then :D
  12. Fatdoi
    i almost pulled the trigger on 1more quad before i saw massdrop plus IEM and now this B400. has anyone tried some of them and give me some impression?
  13. DecentLevi
    @Fatdoi here was a recent review from this thread. More coming
  14. razzer001 Contributor
    To be fair, cables with inline remotes have a higher risk of failure than a cable without inline mic. The actual remote/mic take quite a beating usually from normal usage and they can easily come into contact with sweat which will, if the sweat gets in to the mic/remote housing, corrode the wire connections. Usually cold solder joints caused by corrosion are the main reason a inline remote will stop working, there are ways to stop this, i.e. incase the board in silicone except for the mic, but usually not always effective and come with a string of draw backs.
  15. DecentLevi
    I've always avoided IEM/headphones cables with a mic for the assumption that the extra component (may) reduce fidelity / purety of sound. Not sure how true that is, but in many cases those cables are also made of a lower grade conductor than aftermarket cables... though again that could be different in this case
