Bowers & Wilkins P7 Wireless - Impressions Thread
post-13272981
Post #1,021 of 1,753
ubs28
Does the B&W P7 wireless work good with the iPhone 6S+? I also seem to be reading about hiss, what is that about? How does the P7 Wireless compare to headphones like the HD 650 and the Z1R?
post-13273512
Post #1,022 of 1,753
buyukbang
Update went smooth for me. At %20 P7 disconnects from USB then reconnects and this took some time (like 30+ seconds or so for my experince), but then progress continues from %20 to %100. I can confirm lowest sound steps and didn't notice any other change for the first 10-20 min usage :)
post-13273534
Post #1,023 of 1,753
Bytor123
I updated by Mac after it failed several times on my PC (Windows 10) - took a minute or two. I can't perceive any differences!
post-13273753
Post #1,024 of 1,753
edsjo
I use it with my iPhone 6S. It works fine. I used to have a problem that the lowest volume over wire-less was too loud for some music/circumstances, but with the firmware update this is fixed. The hiss is the noise floor that can be heard with some music (in relatively silent parts). Some don't seem to hear it at all, and some do. I hear it and would be happier if the noise floor was lower, but it is not a deal breaker for me. I tend to listen at relatively low volumes, if you listen louder you probably won't hear it at all. E.g. I cannot hear the hiss when out and around, only in the quiet comfort of my home.
post-13273866
Post #1,025 of 1,753
Unknown364
Hay guys.
I thought this is the best place to ask:
Im debating and cant decide between the P7 Wirelees, MW60 by Master dynamic and the X2 by philips (i know it is not bluetooth).
I like rich sounding headphone. Got the fidelio L1 and had the P5 Wireless that was too bright and lacked some bass so i returned it.
Please your opinion on this 3 headphones.
Thanks alot!
post-13274560
Post #1,026 of 1,753
jmills8
Previously known as bmiamihk
Hong Kong and Miami
Hong Kong and Miami
Hay guys.
Thanks alot!
P7
post-13275135
Post #1,027 of 1,753
ubs28
That is annoying. I suppose I should stick with the Shure SE846 if there is a hiss with the B&W P7 wireless?
If the hiss comes from ANC, is it possible to turn off the ANC so that the hiss will disappear?
post-13275263
Post #1,028 of 1,753
audioxxx
If you keep the source volume on full output, (V10 running Android, in my case) the hiss isn't a problem for me I can barely notice it's there in general. It's nothing like running sensitive IEM's in a noisy source.
The sound is great for Bluetooth, the best I have heard using AptX. You also have the option to plug in and run them as standard headphones.
There is no ANC on the p7w.
post-13279826
Post #1,029 of 1,753
AudioCats
how comfy is the P7 wireless? (comparing to HD580/600 or DT770/880/990)
post-13281706
Post #1,030 of 1,753
Citsur86
Can the P7s be charged while listening through the wired 3.5mm jack?
post-13287677
Post #1,032 of 1,753
headitaly
I did the firmware update, and I have the feeling, as if he had lost power, I can now listen to more low volumes, but feel less intense ... what do you lensate update ?!
post-13287765
Post #1,033 of 1,753
MayaTlab
Paris, France
Paris, France
Ears can be deceiving, so I'm absolutely not sure, but I feel that maybe (really maybe) B&W has altered a little bit the mid-bass hump.
post-13287903
Post #1,034 of 1,753
headitaly
it is likely that you are not just limited to the volume and calls, but also the equalization has changed, now I find the wireless p7 much like they are wired (p7 wireless, wired): lower volume, bass compounds , more balanced sound
post-13292576
Post #1,035 of 1,753
alchemical
Haven't updated yet but out of interest is it possible to roll back the firmware if desired?
